2001 F250 front leaf springs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CATMEISTER, this thread has received 1 replies and been viewed 2264 times.
post #1 of 2 (permalink) Old 08-04-2009, 05:17 PM Thread Starter
2001 front leaf springs with about 2500 miles on them. Not sure on the code but I was told you can get from the part number.
make me an offer located in Idaho
Jay 208-816-6016
ID:	20729   Click image for larger version
CATMEISTER is offline
post #2 of 2 (permalink) Old 08-06-2009, 03:27 PM
As best as I can tell these are "T" code springs rated for 4,000 lbs.
I am no expert this is the best info I can find. Hope this helps.
See below:
Pulled this off another thread a while back-
2003 manual
Front Springs — F-Series
B — F81A-5310-EA
C — F81A-5310-EA
D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
R — 2C34-5310-AAB, 3,600 lb.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
Y — 2C34-5310-VA
Z — 2C34-5310-WA
It seems that the numbers can vary a bit, but the last three alpha characters seem to be consistent.
AC = U code
AD = V code
AE = W code
AF = X code
My V codes are stamped
3 C34 ADA
But I've seen 2 C34 ADB, 3 C34 ADB, 2 C34 ADA... not sure why.
97 F250 7.3PSD,X-Cab,SWB,4X4,5spd,4.10gears,1Owner
3.5 DP,4 Exh.,No Cat,6637 Intake60 gal bed tank,5th whl & gsneck
BDP 140v IDM Mod
CCV mod
'08 diff
Hewitt Gauges
HPX Mod
DP Live Tuned
Modded H2e
3" Billet plenums
BDP E-fuel system
Rosewood 180cc stage II's
Valair full ferramic clutch
Coming soon...
Bigger oil
D-60
'00 Excursion 7.3PSD 4X4, Bone stock...(wife's truck)
6637 intake
drill/slot rotors
Neal 97 250 is offline
The Following User Says Thank You to Neal 97 250 For this addition to TDG:
CATMEISTER (08-06-2009)
SD front leaf springs - V codes 4rcFed Whats Been Sold 20 08-16-2009 12:08 PM
97 Front Leaf Springs 97Beast 1994-2003 7.3L Power Stroke 3 04-25-2008 06:20 AM
front leaf springs seven.three 1994-2003 7.3L Power Stroke 29 12-10-2007 04:20 PM
need front leaf springs seven.three Whats Been Sold 1 11-26-2007 12:30 AM
leveling kit front leaf springs chvylac Whats Been Sold 6 06-29-2006 03:08 AM
