9' 5th wheel aluminum bed/fuel tank - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Duke, this thread has received 8 replies and been viewed 2357 times.
post #1 of 9 (permalink) Old 09-24-2011, 12:52 AM Thread Starter
'Ol Builder guy
Duke's Avatar
Is there enough room on a 9' flatbed equipped with a hidden 5th wheel gooseneck to put a typical aluminum fuel tank against bulkhead and no have interference when making sharp turns?
I know it depends on the trailer construction, but for most typical 5th wheel trailers, will it clear a tank mounted against bulkhead?
I was looking at this model because it's slim (only 9" thick), but it only holds ~45 gallons.
http://www.northerntool.com/shop/tools/product_200306745_200306745?cm_mmc=Google-pla-_-Fuel%20Transfer%20+%20Lubrication-_-Auxiliary&%20Transfer&%20+%20Skid%20Tanks-_-349007&ci_sku=349007&ci_gpa=pla&ci_kw={keyword}
Duke is offline
post #2 of 9 (permalink) Old 10-02-2011, 08:54 AM
Easy way is to hook and measure the neck clearance to the deck and subtract 5 in for out of level unless you are not careful in rough sites at high angles - there seems to be over 6 in difference in the trailers that I have hooked to. If you are hunting a new trailer the should have pin height foe the trailer in the literature and clearance to the neck.
If you are putting a rig together you might look at gooseneck equipment, I like it a lot better off the road.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 9 (permalink) Old 10-02-2011, 01:28 PM Thread Starter
'Ol Builder guy
Duke's Avatar
That's what I am doing-putting a package together.
I have the truck on the way, now looking for the trailer. There's so much to consider!!!
I figured the ultra slim fuel tank would have the lowest chance of interference with the gooseneck.
Duke is offline
post #4 of 9 (permalink) Old 10-03-2011, 10:12 AM
That is what I gathered from the part of the post that I read.
My preference for a gooseneck goes back to backing in on soft stuff with a loaded fifth wheel and losing traction on one side from the trailer tipping, but some stuff is only fifth wheel.
You are seldom really out of shape when the trailer is 90 deg to the truck so that the neck will drop more than 6 in, at about that point the offside starts lifting. So getting the recommended pin height from the manufacture or literature is usually not a problem. Same as backing under the pin to measure with a used trailer - no 5th wheel needed to measure. Wandering through my memory seems there is more than a foot difference in neck clearancs among the stuff that I have pulled.
keydl is offline
post #5 of 9 (permalink) Old 10-09-2011, 05:32 PM
bmoeller's Avatar
When I had my aluminum flatbed (94" wide x 9' long) on my '97, I had my RDS 60 gal tank w/ toolbox with stacks ahead of it, and no clearance issues. My bed had clipped corners at the rear as well. Pulled the flatbed and square nosed Featherlite stock trailer with it.
The top of the ball was maybe 3-4" below the top of the bed.
The one I have-
http://www.nationwidewholesaledirect...49/6416197.htm
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 9 (permalink) Old 10-09-2011, 11:15 PM Thread Starter
'Ol Builder guy
Duke's Avatar
The one I have-
So even at a 90* turn, trailer didn't bind against back of tank/toolbox?
That would be great because I need tool storage.
Duke is offline
post #7 of 9 (permalink) Old 10-11-2011, 01:22 AM Thread Starter
'Ol Builder guy
Duke's Avatar
Im actually looking for a diesel fuel tank & pump for equipment, not a second fuel tank for my truck.
Duke is offline
post #8 of 9 (permalink) Old 10-11-2011, 07:17 AM
bmoeller's Avatar
Nope, no contact.
RDS makes transfer tanks, too. Only posted that so you had a way to judge size for what I have.
bmoeller is offline
post #9 of 9 (permalink) Old 10-12-2011, 11:54 AM Thread Starter
'Ol Builder guy
Duke's Avatar
Something like this, but with a fuel cell would be perfect. I want the tool boxes to be accessible from the ground.
http://cgi.ebay.com/ebaymotors/2005-...item4aaf7b9a2a
Anyone know of such a box/tank combo?
Duke is offline
OBS OEM Aluminum wheel hub covers RLU_tech 1994-2003 7.3L Power Stroke 3 11-19-2010 02:39 AM
NO Fuel Guage READING for FRONT TANK of Dual Tank '94 F250 Ed50free 1994-2003 7.3L Power Stroke 5 03-08-2010 07:25 PM
WTB OBS dually ft. wheel aluminum Russ Ford Parts wanted 0 09-01-2009 01:56 AM
08 aluminum dually wheel hhrecovery Ford Parts wanted 0 08-01-2009 11:23 PM
Aluminum Kenworth Saddle Tank steved Whats Been Sold 2 12-27-2006 01:29 PM
