7 Pin RV Plug - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by campergeorge, this thread has received 4 replies and been viewed 1165 times.
post #1 of 5 (permalink) Old 05-03-2010, 04:12 PM Thread Starter
7 Pin RV Plug
I have a 2006 F-350, does anyone know how to make my positive connector work in my truck female RV Plug? I called Majestic Trailer and they told me that it had to be activated eighter my installing a fuse or a relay. Does anyone know which one and where?
campergeorge is offline
post #2 of 5 (permalink) Old 05-03-2010, 04:24 PM
7.3 addict
look in the owners manual for the fuse panel under the hood it will be called out there as trailer charging circuit HTHs
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #3 of 5 (permalink) Old 05-12-2010, 03:42 PM
Gear jammin fool
Freightrain's Avatar
Yup, should be a relay under the hood. My '96, '99, '00 all had it.
Heck, I drive through Uniontown on my way to/from work. If there is something I can help, let me know.
United Manual Transmission Racers
2006 UMTR Points Champion
2009 UMTR Points Champion
Built like a MACK truck
1959 B61 Mack
Freightrain is offline
post #4 of 5 (permalink) Old 05-12-2010, 04:48 PM
bushpilot's Avatar
I thought the 04+ 6.0L has the trailer charge relay IN PLACE...its live from the factory
as far as i know <in fact i recently used the wire for a relay signal>.
Don R.
Truck Audio,
bushpilot is offline
post #5 of 5 (permalink) Old 05-12-2010, 07:04 PM
Gear jammin fool
Hmmm, maybe it's just burnt up?
Just like the fuel pump relay on the '01 F150 at work(just put third one in just a couple weeks ago).
Should be a fuse also?
1959 B61 Mack
To Plug or not to Plug? rowdyrider 2003-2007 6.0L Power Stroke 10 12-05-2009 02:49 PM
Plug in powerstroke7.3 1994-2003 7.3L Power Stroke 2 01-25-2008 07:43 PM
problem checking glow plug with 5 pin plug Firefighter E2 1994-2003 7.3L Power Stroke 1 11-25-2007 06:18 PM
Where does this plug in to? Pix blackpsd 5.9L Cummins (1998.5-2002) 50 07-14-2007 04:33 AM
map plug?? dustindiesel General Ford Truck and Excursion 3 01-06-2007 06:24 AM
