Steering gear box slop - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by legend10, this thread has received 6 replies and been viewed 10513 times.
post #1 of 7 (permalink) Old 09-03-2010, 07:37 PM Thread Starter
legend10's Avatar
Got a 83' 359 pete with some slop in the steering gear box, is there anyway to fix that without replacing the box? It looks like it has 2 adjustment screws with jam nuts on the bottom. Thanks
legend10 is offline
post #2 of 7 (permalink) Old 09-03-2010, 10:24 PM
I have been told that you don't want to try to adjust the box. Heard of a guy doing that and missed a curve. I guess it was fine for a while but totally went to hell and caused a crash. Our mechanic refuses to touch one, he said just swap it it's not worth the risk. But maybe yours is different than the newer ones.
Jfaulkner is offline
post #3 of 7 (permalink) Old 09-04-2010, 01:47 AM
Well you can adjust the sector shaft (thats wear the play is) dont touch the adjustments on the end's of the box thats the steering stop/ relef. the sector shaft if adjusted to tight on a worn box WILL bind when you make a full left or right turn. so hears how you do it the sefe way, the adjustment is in the rear of the box towards the frame in the middle of the box. There is ushualy a hole in the frame rail to get to the jam nut and adjuster. Now jack up the truck and turn the wheel to the left or right, turn in on the adjuster untill you feal increased pressure mabe a 1/4 turn, lock your jam nut and turn the wheel to the other extreme (with the truck off) feal for bindeing if there is bindeingback off on your adjustment. how mutch you can adjust depends on if it binds when you make a full turn bindeing is BAD you may have steering problems if you set it tight as stated
I still requemend replaceing the box but its up to you. good luck
BLACKKW is offline
post #4 of 7 (permalink) Old 09-04-2010, 04:02 AM
phantom309
3406bcat's Avatar
id replace with rebuilt, dont chance it. i put new one on mine and drives like a new one now...
3406bcat is offline
post #5 of 7 (permalink) Old 09-04-2010, 06:39 AM
O'Skool Member
Red Diesel's Avatar
What brand and model? Procedure might be listed in my F-liner manual (it covers several types).
I did mine about two years ago. Got it back to like new play in steering wheel.
It warned that the adjusting screw is staked in (!!!) and if you turn it wrong the sector shaft can just come right out while driving. Sounds like an unsafe design to me. All that stands between staying alive or crashing and burning is a staked in screw! WTF?
Red Diesel is offline
post #6 of 7 (permalink) Old 09-04-2010, 06:41 AM Thread Starter
legend10's Avatar
lol well ill just get a new one! Any rough idea what they cost?
legend10 is offline
post #7 of 7 (permalink) Old 09-04-2010, 06:35 PM
bullhauler89's Avatar
last one i bought was like 500 exchange
2007 pete 379 exhd flattop single turbo bxs with some go fast parts
bullhauler89 is offline
Proper fix for spring shackle slop legend10 Medium and Heavy Duty 8 06-07-2010 01:30 AM
Steering Gear Production Code Z3A or Z3B? JMeier 5.9L Cummins (1998.5-2002) 0 01-11-2010 03:13 PM
steering gear leaking and trans lines expletive0 Duramax 2006-2007(LBZ & LLY) 7 02-26-2009 12:06 PM
To re-gear or not to re-gear, that is the question Lonesome7.3 1994-2003 7.3L Power Stroke 99 02-28-2008 07:05 PM
t444e power steering gear ford572 Medium and Heavy Duty 5 06-18-2007 03:28 AM
