1 - 15 of 15 Posts
oldskool359
· Junior Member
Discussion starter · #1 ·
Was wondering what turbo you guys recommend for my 3406 Cat? I am goin to get industrial injectors and I need a turbo to move some air. I was told to get a cummins turbo, but someone told me that if you get the right CAT turbo it will do just as well! Im tired of getting passed by a 500 Cummins in my bosses pete so I want to upgrade the old girl.
Borg Warner 199119. Or 198123 if you flow enough fuel.
Follow Tony's pump mods, and you'll be right on.
The 3406C - 460 turbo is pretty much the same as the 199119, but if yiou have to buy one out right the 199119 should be cheaper
turbo
I have a c model turbo on mine OR-6051 get along great with it. You can buy it no core from a borgwarner dealer (schwizer borg warner same company) mine ran 1100 but that was a year or two ago, I was running the holset ht 60 before it was fast to spool up but it ran outta steam faster after bolting on the 6051 i noticed a jump in torque and lower temps..
http://thedieselgarage.com/forums/showthread.php?t=2709[/url]
:sprayw
I kind of put that one in the toilet Didn't I ?:fan
Normally I check to see that the links work :bang
Good to see you are still with us Tony.
Here is a BW link that Tony gave us quite a while ago (I don't know if you newer members know about the "handy links sticky At the top of the HD forum)
https://www308.safesecureweb.com/iponly140864//pdf/BW_S_series_replcmnt_CAT.pdf
Lots of stuff like this in there and if you have good links feel free to add them :thumbsup
Reactions: kenw007
1 - 15 of 15 Posts
