In-frame, out-frame, or park-frame? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bkdoubleu, this thread has received 15 replies and been viewed 3619 times.
post #1 of 16 (permalink) Old 10-21-2010, 06:39 PM Thread Starter
Okay guys I have a 1996 International 4700 (old Fed-Ex) truck. 271K on DT466E. Blows a ton of oil out the bypass hose. DOT is particular about that it seems these days, Dealer hooked a manometer up to it and the reading is 6.5". Everyone wants to overhaul it for about 8K. Engine has lots of power still and sounds tight. I am wanting to rework this engine myself.
Is there some reason I simply can't just re-ring this, change the o-rings on the liners, r&r the rod bearings, freshen up the head and haul ***? or have things changed in the last 20 years since I last cracked open a diesel engine?
Your thoughts?
Thanks
bkdoubleu is offline
post #2 of 16 (permalink) Old 10-21-2010, 08:11 PM
379Longhood's Avatar
Last I heard the kit for those engines was cheap from IHC , don't know if the addition of electronics changed that
nothing majic inside just a bunch of metal stuff
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #3 of 16 (permalink) Old 10-22-2010, 12:15 AM
Not sure about that one, Jim... stuff inside some engines baffles the sht outta me...
Easy for some of you guys(You, Tony,John,Kurt, Pichu and many others)
black_dog106 is offline
post #4 of 16 (permalink) Old 10-22-2010, 12:58 AM
If it is running smooth, I would get a rubber diaphragm and test the turbo for air bypassing the compressor to the crank case, also test the CAC and the intake manifold for air past the valve guides. You Should be able to get an adapter, that goes into the injector hole and do a leak down test on the cylinders. Do the test at the TDC each cylinder and at the bottom, cut apart the oil filter looking for metal.
You want all the information you can get, then make a decision with the facts, not every engine that looks bad is junk, and needs an overhaul.
Just a thought!
Johnp3 is offline
post #5 of 16 (permalink) Old 10-22-2010, 01:54 AM
Engine in-frame parts about $1500 for non electronic DT. I would think E model about the same. No point in replacing electronics that work.
'93 IH 4700, 250HP DT466, L10 Cummins intercooler, 6+1, air ride.
Case 580 Super E
Galion 503 A
Cat D8H
JD A, B, MT, 40T (x2), 80, 720
Oliver 60
IH A, H, M(V8), 354, 444
johndear720 is offline
post #6 of 16 (permalink) Old 10-22-2010, 02:08 AM
Just a thought!
JD 820 black dash
post #7 of 16 (permalink) Old 10-22-2010, 04:30 PM Thread Starter
you know that makes more sense. I have a hard time that with that much blow by this truck could run this good. It hauls oilfield supplies so you can imagine its never overloaded. lol
Thanks for the tip. Now I get to go and diagnose!
di-ig-nos: v to recognise by signs or syptoms.
post #8 of 16 (permalink) Old 10-22-2010, 09:15 PM
DT 466E= a good engine. I have a lot of experience with these little engines. Check that the valve cover gasket is in good shape. The valve cover doubles as the intake manifold. A weak gasket could let turbo boost pressure enter into the crankcase and slobber oil out the tube. Just a thought. Oh yeah a bit off topic but most of these have a small cylinder thing just to the rear of the fuel filter head. It has a screen in it and a lot of people overlook them when they service these engines.
nceaglene is offline
The Following User Says Thank You to nceaglene For this addition to TDG:
Johnp3 (10-23-2010)
post #9 of 16 (permalink) Old 10-23-2010, 12:53 AM
Hate to but in but a friend of mine had his automatic trans rebuilt only to find out that it was the clogged screen after his truck showed the same signs after trans job as before. Needless to say cleaning screen cheaper than transmission and a good mechanic PRICELESS!!!!
unforgiven76 is offline
The Following User Says Thank You to unforgiven76 For this addition to TDG:
nceaglene (10-26-2010)
post #10 of 16 (permalink) Old 10-23-2010, 01:09 AM
You say that its dumping oil out the breather tube, inside the top of the valve cover is 2 brillo pad looking things that stop the oil from getting out. If one or both of them have the centers pushed out it will dump oil out the tube. As was said earlier check your valve cover gasket.
BLACKKW is offline
creaky frame drgriff General Ford Truck and Excursion 10 11-04-2009 04:43 PM
New frame rails cow doc Medium and Heavy Duty 10 08-06-2009 12:18 AM
92 frame Pleace 69 Whats Been Sold 2 04-01-2009 07:15 PM
frame strengthening. ckbed Diesel Conversion 6 02-14-2008 01:06 AM
07 Frame TooMuchBoost 2008-2010 6.4L Power Stroke 19 02-24-2006 03:24 AM
