1lw head install question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dp90sled, this thread has received 2 replies and been viewed 921 times.
post #1 of 3 (permalink) Old 12-18-2010, 10:48 PM Thread Starter
I just installed a new head on a 1lw, my question is, how do you determine if the engine is pinned on #1 or #6? or does it even matter? Does the cam actually determine which one will be on compression? If I'm not mistaken as long as the flywheel is pinned an the cam gear is installed lined up with the timing marks everything should be fine right? Any input would be greatly appreciated!
dp90sled is offline
post #2 of 3 (permalink) Old 12-19-2010, 12:14 AM
Sounds like you answered your own questions! your on the right track.
05chopper is offline
post #3 of 3 (permalink) Old 12-19-2010, 03:45 AM
SledMan's Avatar
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
head stud install next February 1st. Quantum 2008-2010 6.4L Engine Tuner Forum 22 02-10-2010 01:55 AM
Driveway Head-stud install 101 Eviltwins 2008-2010 6.4L Engine Tuner Forum 7 10-16-2009 02:12 AM
Head install questions bad_cummins 5.9L Cummins (Pre 1994) 4 04-24-2008 02:26 AM
Head stud install in NorCal? NCR 2003-2007 6.0L Power Stroke 2 10-05-2007 02:30 PM
dealer install head studs? 04-F350 2003-2007 6.0L Power Stroke 9 12-08-2006 03:31 PM
