3116 Cat compression tester - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mack Doctor Jr., this thread has received 10 replies and been viewed 6370 times.
post #1 of 11 (permalink) Old 01-26-2011, 02:49 AM Thread Starter
Mack Doctor Jr.'s Avatar
Well after a couple of days trying to figure out how to do a compression test on this 3116 we finally made our own. My old man spent hours today on the lathe to make a dummy injector. We will give it a try tomorrow.
ID:	27985   Click image for larger version
Mack Doctor Jr. is offline
post #2 of 11 (permalink) Old 01-26-2011, 04:20 AM
The other guy
ynot is offline
post #3 of 11 (permalink) Old 01-26-2011, 04:26 AM
Highway to Hell
Lmackattack's Avatar
Nice. We are having troubles with a 3116 also. We have air in the fuel system
1978 MACK RS700L
285 HP @2100 RPM 1080 TORQUE. @1200 RPM
2 STICK 6 SPEED, 4.17 REARS ON 34K CAMELBACK SPRINGS,206"WB, 4" STRAIGHT STACKS BLOWING BLACK,
OH...AND A FEW TWISTS OF THE FUEL SCREWS ....THANKS AGAIN... FJH!
Lmackattack is offline
post #4 of 11 (permalink) Old 01-26-2011, 04:42 AM Thread Starter
As many man hours the old man put into this thing, I told him to rent it to Cat across the street from us to get his money out of it..
post #5 of 11 (permalink) Old 01-26-2011, 05:51 AM
Nice job.
Johnp3 is offline
post #6 of 11 (permalink) Old 01-26-2011, 07:25 PM Thread Starter
worked like a charm! had to take the injector rocker off and put the rest of the assembly back on. 380 psi on #1 and 400 psi on the rest. Mechanic working on it thinks the injector rocker was holding it open maybe thats the prolem.
post #7 of 11 (permalink) Old 01-26-2011, 08:12 PM
Highway to Hell
whats it doing?
1978 MACK RS700L
post #8 of 11 (permalink) Old 01-26-2011, 09:13 PM
I would do a cylinder leak down test, at TDC and BTC.
Just a thought!
Johnp3 is offline
post #9 of 11 (permalink) Old 01-27-2011, 12:44 AM Thread Starter
Well it was getting real hard to start. The idiots in the yard where using etheron it in the summer. So our new mechanic (that actually came from Altolfer) is working on it. He recut the cups ( or reshaped them ) with the use of cats tools. We then bought REMAN injectors and had 2 bad ones and took them back. So now at an idle its over fueling if u step on the pedal it turns black. But at an idle it is over fueling so bad that the muffler is filling up with raw fuel. The infra-red heat gun shows that # 1 is 100 degrees cooler than the rest. We now think that the injector rocker is set to tight or may be hanging up a little. We did swap injectors around and #1 still shows signs of being cooler than the rest. He has already did the same thing to another loader at the same time and its done already. The other one got a new fuel pump and both got the fuel return check valve replaced..
post #10 of 11 (permalink) Old 01-27-2011, 01:57 AM
Highway to Hell
We were having a problem with the truck not starting also. every time it turned off it would louse prime. Checked for air leakes, changed check valve orings etc.. still was a PITA to start. I then pulled the feed and retrun lines and primed it out of a bucket. still was hard to start. Once I got it running the return was pushing out foam. We tore into the injectors and found that # 2 and 6 were acting up. We think we have it figured out. I was not at the shop today but the mechanic said that they replaced cups and will need to set the injector hights. something about a dropped injector? Dont know what that means, as all the injectors I have ever put in just bottom into the housing and then you bolt them in..simple!
1978 MACK RS700L
Nozzle tester Fahlin Racing General Diesel 5 11-29-2012 07:48 PM
JD Crop Moisture Tester. Haloman Everything Else 1 10-07-2009 09:31 PM
Info needed: 7.3L injector balance tester. harleyengineguy 1994-2003 7.3L Power Stroke 0 03-08-2009 11:26 PM
Battery Tester VONDIESEL General Ford Truck and Excursion 1 12-14-2007 03:12 AM
Has anyone checked out where u can be a tester for edge? BigFordOn24s 2008-2010 6.4L Engine Tuner Forum 4 06-09-2007 09:53 AM
