Which Nozzles? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CAT625, this thread has received 13 replies and been viewed 6356 times.
post #1 of 14 (permalink) Old 03-01-2011, 11:47 AM Thread Starter
Which Nozzles?
Hey guys, I'm currently building a 3406c mechanical with 1260736 steel two piece pistons and was wondering if anyone would know the best nozzles to run for more power. Also is running a 7fb pump better than a 3zj one in this build.... All help is greatly appreiciated.
CAT625 is offline
post #2 of 14 (permalink) Old 03-01-2011, 02:17 PM
SledMan's Avatar
I was going to say OR-8785...but the B pump won't push these. Well, It will, but after a short time, it will start putting fuel in the oil. It will wear the plungers trying to compensate for the higher PSI.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
post #3 of 14 (permalink) Old 03-01-2011, 08:44 PM Thread Starter
Thanks SledMan, but if i use the 3zj pump those injectors would be alright, won't they?
CAT625 is offline
post #4 of 14 (permalink) Old 03-01-2011, 11:46 PM
379Longhood's Avatar
Tony posted an iron set list for a "C" build ,a few months ago , link to his list
https://www.thedieselgarage.com/forum...d.php?t=108187
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #5 of 14 (permalink) Old 03-02-2011, 03:17 AM
SledMan's Avatar
As long as the pump is cast with 7E-5888 on the side, it will push the OR-8785's.....you are correct.
SledMan is offline
post #6 of 14 (permalink) Old 03-03-2011, 09:21 PM
cattlepuller
I have a late C model 8PN and was buying new injectors but I was giong to buy the OR8995's. Whats the difference between the OR8995 and the OR8785's. I'm ordering them today so any help would be greatly appereciated. Thanks.
cattlepuller is offline
post #7 of 14 (permalink) Old 03-04-2011, 12:34 AM
SledMan's Avatar
8785"s are Marine application.....580HP
SledMan is offline
post #8 of 14 (permalink) Old 03-04-2011, 03:26 AM
SmokinCAT's Avatar
Curious as to why you went with the 2 piece pistons, are you shooting for over 800hp.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #9 of 14 (permalink) Old 03-04-2011, 03:36 AM
cattlepuller
thanks sledman I ordered the 8785's. will I need to do any work in the pump with the gov spring or shims its a 7e 5888 casting pump. I'm trying to beat my buddies 550E he told me I was wasteing my time.
post #10 of 14 (permalink) Old 11-17-2011, 01:45 AM
3406 nozzles
OR-8785 with 7e-5888 pump and OR-3421's with 7w-3906 injector pump is the best nozzles to go with. as far as which pump is better i suppose that is personal preference, the 7w-3906 "7fb" pump has more fuel less pressure and the 7e-5888 dual scroll 3ZJ pump has more pressure less fuel delivery
greasemonkey is offline
The Following User Says Thank You to greasemonkey For this addition to TDG:
377pete (10-18-2012)
Getting new nozzles 5.9 Blackout 5.9L Cummins (2003-2007.5) 3 11-25-2010 05:04 AM
3406B Nozzles ar4cuda Medium and Heavy Duty 27 06-02-2010 04:55 AM
Nozzles kc04 5.9L Cummins (1998.5-2002) 2 04-11-2010 06:17 PM
80 to 100% over nozzles camojeeper Ford Parts wanted 0 11-03-2009 05:43 AM
looking for 40% or bigger nozzles for lly fwdcummins Whats Been Sold 4 11-13-2007 02:28 PM
