Oil consumption after overhead ran... 1LW 3406E - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Les2, this thread has received 10 replies and been viewed 3985 times.
post #1 of 11 (permalink) Old 03-12-2011, 12:40 AM Thread Starter
What could cause this? Its my cousins truck, he had someone run the overhead and then it started using oil real bad. It also has major blowby.
When you run the overhead on one of these do you mess with injector high or anything like that?
Could it be the air compressor? Thats what they are leaning toward but to me, I think if it was that it wouldn;t be buildin any air at all. He goes thru a gallon every 1000 miles?
The truck runs great! It was supposedly rebuild 300k ago.
Les2 is offline
post #2 of 11 (permalink) Old 03-12-2011, 12:44 AM
There is always the chance that the air intake was loose and eating dirt in the intake some were. I have seen that a few times.
theakerstwo is offline
post #3 of 11 (permalink) Old 03-12-2011, 01:51 AM
379Longhood's Avatar
when the overhead is set, the inj height should be checked with a Cat guage, the tolerances are +/-0.002 from memory, Is the compressor putting oil in the wet tank?? If the consumption and blowby just showed up after the overhead, you would think it has something to do with the problem, not real sure what tho, Is the blow by just at dead idle or across the board?? and does compressor cycle seem to have any thing to do with it??
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #4 of 11 (permalink) Old 03-12-2011, 03:50 AM Thread Starter
Just remembered.... it has a miss or just plain idles rough.
THe blowby seems to be all the time. It smoke blue smoke when he starts it, cold or hot.
Theakerstwo what do you mean about the intake? You mean for the compressor or motor?
Les2 is offline
post #5 of 11 (permalink) Old 03-12-2011, 04:05 AM
Sounds like tight intake lash to me
JD 820 black dash
post #6 of 11 (permalink) Old 03-12-2011, 01:17 PM Thread Starter
I'll ask him some more questions today when I see him just to make sure I got everything right.
Les2 is offline
post #7 of 11 (permalink) Old 03-12-2011, 02:45 PM Thread Starter
Remembered one other thing. He says he keeps clogging the oil filter. What would cause that?
Les2 is offline
post #8 of 11 (permalink) Old 03-12-2011, 02:59 PM
Look at the intake piping and see if its not eating dirt. After a engine eats dirt it will be wore out and this will let carbon into the oil. That will stop a filter faster.
The Following User Says Thank You to theakerstwo For this addition to TDG:
Les2 (03-12-2011)
post #9 of 11 (permalink) Old 03-12-2011, 07:29 PM
The other guy
I'd lean that way also. Sounds like it got dusted. Check the tubes!!!
ynot is offline
post #10 of 11 (permalink) Old 03-13-2011, 09:44 PM Thread Starter
Bet thats it also. He told me yesterday he was running it with a boost leak that he couldn't find. He found it, it was a boot that had a hole in it.
Les2 is offline
Oil consumption Klutch 2008-2010 6.4L Engine Tuner Forum 0 06-27-2010 04:20 PM
oil consumption toshmago 2003-2007 6.0L Power Stroke 11 07-07-2009 04:05 AM
7.3 oil consumption highboy diesel 7.3L and 6.9 IDI (Pre 1994) 5 11-13-2007 03:51 AM
Oil consumption oldmikegraham 1994-2003 7.3L Power Stroke 12 11-04-2006 11:09 PM
Oil Consumption bigdraft 1994-2003 7.3L Power Stroke 15 03-06-2006 02:09 AM
