3406 Injection Pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bluetrucker94, this thread has received 3 replies and been viewed 2264 times.
post #1 of 4 (permalink) Old 10-01-2011, 08:52 PM Thread Starter
3406 Injection Pump
Had a bad plunger/barrel assembly. Installed new assembly and seems to be out of time. Cracked injector line at head plenty of pressure. Also does not die when shut down, runs for a few seconds. Any suggestions guys??
Bluetrucker94 is offline
post #2 of 4 (permalink) Old 10-01-2011, 09:08 PM
379Longhood's Avatar
Maybe the plunger isn't timed to the rest of the rack. some where on here Tony gave the instructions for replacing B&P s
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #3 of 4 (permalink) Old 10-01-2011, 09:22 PM Thread Starter
Believe that is where the problem, lies try to find that thread
post #4 of 4 (permalink) Old 10-01-2011, 11:52 PM Thread Starter
Figured out the issue. Had timing pin on the wrong end of rack slot. Moved to engine side. reinstalled P/B, sounds like a 3406. Up and running
3406 a/b/c transfer pump rebuild kit fest777 Medium and Heavy Duty 7 05-31-2014 05:31 AM
3406 Pump? fastshovelhead Medium and Heavy Duty 8 08-30-2011 02:14 AM
Mechanical injection for 3406 E , C-15,C-16 379Longhood Medium and Heavy Duty 2 01-10-2011 03:34 AM
3406 fuel pump ktw900 Medium and Heavy Duty 6 03-14-2010 05:41 PM
I need an injection pump and an aftermarket lift pump for my 98.5 24v CRAZY ROB Dodge parts wanted 2 02-10-2010 07:35 PM
