Turning up 3406C Cat - Page 6 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ParkerFly, this thread has received 65 replies and been viewed 66969 times.
 2Likes
post #51 of 66 (permalink) Old 01-21-2012, 10:54 PM
Originally Posted by fastshovelhead View Post
Put the AFC housing back on.
The screws are lower, behind a small metal cover being held in place with two bolts. Turn both out equal turns.
It is the lower most cover on the pump. It is also closest to the drivers side of the truck on the pump.
Don't just crank the screws all the way out. If you go to far with the screws you will loose the torque rise, and responce/performance will suffer slightly.
-Aaron-
2001 Volvo VNL 660
2001 Western Star 4964FX Viper Red
AaronF is offline
post #52 of 66 (permalink) Old 01-22-2012, 01:05 AM
Fastshovelhead and AaronF are both right. Make sure you hook the little yoke over the plunger when putting the afc back on. The cover with the fuel & torque screws is a S shaped cover with a 7/16 & 3/8's head if I remember right.
cowpuncher is offline
post #53 of 66 (permalink) Old 01-22-2012, 02:04 AM Thread Starter
Pulling Sled for hire
ParkerFly's Avatar
I already had it put back together and ran it to make sure everything was working alright. Just to make sure I wasn't losing my mind I went back and read the instructions I had and they said to remove the afc housing. Guess I'll find some new instructions if they're that bad off.
Heartbreaker 2 Pulling Sled - http://heartbreakersled.webs.com
1997 F-250 Power Stroke - 290k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
ParkerFly is offline
post #54 of 66 (permalink) Old 01-22-2012, 03:11 AM
fastshovelhead's Avatar
That sounds like a idea! There is a lot of knowledgeable people here that can help you.
The dumbest question that can be asked is the one you never do.
GOOD LUCK!
Going Nowhere Fast
fastshovelhead is offline
post #55 of 66 (permalink) Old 01-22-2012, 07:59 AM
O'Skool Member
Red Diesel's Avatar
https://www.thedieselgarage.com/forum...ad.php?t=27097
Re-post of Tony's original by neverenufhp.
The first paragraph deals with the AFRC. The rest is for the rack adjustment (fuel screws).
Except last two paragraphs - timing and turbo.
Rack screw cover is bottom left. 2 bolts - 7/16 socket.
Your CAT shop should be willing to email some diagrams if you call and ask.
Red Diesel is offline
post #56 of 66 (permalink) Old 01-22-2012, 02:19 PM Thread Starter
ParkerFly's Avatar
I've already done the springs method and it didn't make any difference in power. I also adjusted the AFC setting, and then set it back to stock because I didn't like the touchy throttle. I hope to try for the actual fuel screws this afternoon now that I've got some directions that make sense
463 hp - 7-9-09
post #57 of 66 (permalink) Old 04-25-2019, 03:09 PM
Big Cam Power!!!!!
LOG HAULER's Avatar
Where is this guy?
Get right before you get left!
91 Taurus SHO 220hp
2005 GS 430 300hp
1985 Freightliner FLC Big Cam 350 No Mods Yet
1979 Kenworth W900 Big Cam 550Hp
If it aint something it's something else!!
Add Me on FACEBOOK .....ROC KENWORTH
LOG HAULER is offline
post #58 of 66 (permalink) Old 04-25-2019, 03:12 PM
Big Cam Power!!!!!
LOG HAULER's Avatar
Originally Posted by ynot View Post
Keep the small turbo. It won't get much speed out of that cam, pump cam and piston set-up. Cranked. 6 turns on the rack and the purple spring and shim set. Max the AF/C. 0R8785 nozzles and timing at 17.5 and startscrew at 1240. Keep it above 1450RPM and always probe it post turbo so others can compair it to theirs without math. You'll get 500 out of it. More with a super turbo or slower pistons... or both.
Where is this guy!!
91 Taurus SHO 220hp
2005 GS 430 300hp
post #59 of 66 (permalink) Old 04-26-2019, 04:15 PM
Super Moderator
nevrenufhp's Avatar
Originally Posted by LOG HAULER View Post
Where is this guy!!
Ynot (Tony) left a while back. I had his number for a while, but he changed it. I really dont know how to find him.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #60 of 66 (permalink) Old 04-26-2019, 06:38 PM
Big Cam Power!!!!!
LOG HAULER's Avatar
oh wow, its been a minute ...I wonder how many of the old boys are still here
91 Taurus SHO 220hp
2005 GS 430 300hp
3406C cam heallen Medium and Heavy Duty 4 04-21-2011 07:03 PM
New Guy here with 3406C DDT3406 Medium and Heavy Duty 10 01-04-2011 11:51 PM
3406C 8PN oil psi??? CumminsISXpower Medium and Heavy Duty 8 10-25-2010 06:56 AM
3406C heallen Medium and Heavy Duty 5 05-21-2010 03:09 PM
Cat 3406c McDiesel Medium and Heavy Duty 0 10-16-2006 08:50 PM
