found cat 3406b injection pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 377pete, this thread has received 3 replies and been viewed 1871 times.
post #1 of 4 (permalink) Old 04-19-2013, 03:50 AM Thread Starter
a freind of a freind has a ford dump truck with a blown 3406 b . rod went thru side of block. i can have the pump for $250. he had it resealed two years ago. its missing one injector line that he sold to a freind and did not cover the bushing. the hood stays closed. should i worry about anything gettting in there. should i have it gone thru. need also someone in the dallas area that is willing to take it off and put in on mine. i need to replace mine becouse i get fuel in my oil.
377pete is offline
post #2 of 4 (permalink) Old 04-19-2013, 05:57 AM
$250 for a used pump sounds like a good deal if it is a good one. I wouldn't be too worried about the line being left off unless it was in a very dirty environment. When you get it on your truck you could flush it out with the hand primer pump before installing the line. At worst you may need to replace that barrel. Might not hurt to take a snap shot of the blown engine's data tag for reference should you need the numbers from it. Fuel settings will probably be different but hard to say if it will be something noticeable. Just wondering if you are certain that your fuel in the oil problem is being caused by the injection pump? Usually it is caused by a bad fuel nozzle.
techmech is offline
post #3 of 4 (permalink) Old 04-19-2013, 06:52 AM
SledMan's Avatar
As stated, could be nozzle leaking. As could inner line, nozzle pop screw, etc. I would not replace the pump unless it is indeed the cause of the leak. Usually the engine will have a skip or miss if a plunger is bad enough to leak.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
post #4 of 4 (permalink) Old 04-19-2013, 03:19 PM
The other guy
My vote is still the same one. Nozzle bleed screw
ynot is offline
Cat 3406b Injector Pump Leaking at Top HTDPete Medium and Heavy Duty 2 09-13-2012 10:03 AM
Cat injection pump rebuild 377pete Medium and Heavy Duty 0 05-05-2012 03:10 AM
Oil leak at injection pump 3406b 377pete Medium and Heavy Duty 5 12-13-2011 02:49 AM
cat injection pump leak 377pete Medium and Heavy Duty 4 02-26-2011 02:29 AM
Cat 3406B Pump Performance Limits? turboIH MD and HD - Modification Instructions, Product Installs and Tech Articles 1 04-03-2008 05:02 AM
