6NZ turbo and manifold. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 12vjake, this thread has received 12 replies and been viewed 5132 times.
post #1 of 13 (permalink) Old 09-26-2015, 04:09 AM Thread Starter
12vjake's Avatar
Just did a flange gasket on my dads 6nz cat and found the center divider on the manifold and turbo are warped and flaking. I've read s lot of posts about a good Borg Warner turbo replacement but not to sure on what the best manifold is out there. Does Mr Hsndy still go business? What's everyone running now days?
CAT POWER
12vjake is offline
post #2 of 13 (permalink) Old 09-26-2015, 06:37 AM
Lost in the dust
I just put a pdi on mine , the shop is a dealer and from looking on the web it wasn't that out of line for aftermarket and they said it was better than the 600 dollar ones one some sights , it dose run cooler egt now but I had so mush fixed ( CAC, turbo , manifold , head set ) I'm not sure what did the most good
Mark5ds600 is offline
post #3 of 13 (permalink) Old 09-26-2015, 03:22 PM
Probably the entire combination, every one of those items need each other to achieve maximum result.
I have a Bully Dog and it did help a very small of cooling, since mine never had hi temps, but the manifold was leaking a little bit on two places, I think the help came from the bigger port and polish.
H800T is offline
post #4 of 13 (permalink) Old 09-27-2015, 02:46 AM
Lost in the dust
I'm with you 100% , we fixed so many small problems it's hard to tell if any of the aftermarket stuff made a big enough difference to be worth the money , I do think at this point the aftermarket guys are working hard and sights like this are keeping them honest so you are getting a higher quality product but it's still up to each guy to decide if it makes sense in his business to spend that extra cash , we did and time will tell if it was wise
post #5 of 13 (permalink) Old 10-14-2015, 03:26 AM
In for more comments
ls1freek is offline
post #6 of 13 (permalink) Old 10-14-2015, 09:27 AM Thread Starter
12vjake's Avatar
Wish I knew how to get ahold of Mr Haney.
12vjake is offline
post #7 of 13 (permalink) Old 10-19-2015, 02:27 AM
Why do you want to get ahold the Dr.
kat man is offline
post #8 of 13 (permalink) Old 10-19-2015, 05:17 PM Thread Starter
12vjake's Avatar
I don't know if he is still selling his stuff. If not I'm sure he could tell me where to go.
CAT POWER
12vjake is offline
post #9 of 13 (permalink) Old 10-20-2015, 10:07 AM
SmokinCAT's Avatar
PDI builds the better manifold currently, doesn't really matter where you go as anyone that sells them should be priced according to PDI.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
The Following User Says Thank You to SmokinCAT For this addition to TDG:
12vjake (10-20-2015)
post #10 of 13 (permalink) Old 10-20-2015, 08:01 PM Thread Starter
12vjake's Avatar
Is the pdi manifold much better than factory? I want to avoid the breaking down of the divider in the future. I've also heard of running a b model manifold. Any thoughts on that?
CAT POWER
12vjake is offline
? on stock 6nz turbo Pete379EXHD Medium and Heavy Duty 11 05-19-2015 09:21 PM
6nz tune and turbo help timepiece Introductions 1 02-23-2015 09:34 PM
6NZ Borg warner turbo no. Hotrodherman Medium and Heavy Duty 16 02-14-2015 11:23 AM
cy 6nz turbo hunt jlbt Medium and Heavy Duty 20 09-01-2014 09:50 PM
Need 6nz turbo gaspedal99 Medium and Heavy Duty 33 11-01-2011 04:42 PM
