Knocking 3406b frustrated !! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Engine fairy, this thread has received 9 replies and been viewed 2094 times.
post #1 of 10 (permalink) Old 03-31-2016, 06:05 AM Thread Starter
Angry Knocking 3406b frustrated !!
Customer brought me this truck already taken apart didn't hear it run. Said 3-4-5 were full of water motor wouldn't turn over they pulled the head. Then I got it. Exchanged head reassembled got coolant in oil. Teardown and inspect. Found cracked liner. Replaced all 6 cyl packs oil pump and all bearings. Started up smooth but has a knocking noise at the front lower end checked everything can't seem to find the knock.
Engine fairy is offline
post #2 of 10 (permalink) Old 03-31-2016, 02:16 PM
Check for broken crank.Use a bar on the front to pry crank forward and a screw driver on the flywheel and pry it backwards.
theakerstwo is offline
post #3 of 10 (permalink) Old 03-31-2016, 02:42 PM Thread Starter
I've done that several times. Pulled rod caps back off pulled main caps. Can't find anything.
post #4 of 10 (permalink) Old 03-31-2016, 04:56 PM
Did you match part numbers on bearings, could have cut crank.
booboo is offline
post #5 of 10 (permalink) Old 03-31-2016, 05:03 PM Thread Starter
They were aftermarket but no signs of oversized
post #6 of 10 (permalink) Old 03-31-2016, 07:30 PM
Could be fuel knock from bad nozzle on #1.
Are nozzles new?
Does it smoke at all?
swaan is offline
post #7 of 10 (permalink) Old 03-31-2016, 07:35 PM Thread Starter
Yes the nozzles are new and it smokes very little
post #8 of 10 (permalink) Old 03-31-2016, 09:59 PM
SmokinCAT's Avatar
Does it change tones? When mine went back together I had a know that would come and go, I had to crack all the lines before it went away.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #9 of 10 (permalink) Old 04-01-2016, 12:34 AM Thread Starter
it stays the same even when you crack the lines loose
post #10 of 10 (permalink) Old 04-04-2016, 07:40 AM
w9l
w9l's Avatar
Air compressor about to chuck a rod? Depending on type, advance carrier trying to grenade and hitting cone cover? Balancer slipped (if not updated to fluid typealready) or loose.
w9l is offline
The Following User Says Thank You to w9l For this addition to TDG:
Oxbow12 (04-05-2016)
Frustrated Ford psd owner ! Lauless Transfer Introductions 5 01-03-2013 12:46 PM
Cummins M11 280E - Very Frustrated! palengineer Medium and Heavy Duty 9 01-01-2012 04:31 AM
Need some help guys! FRuSTRATED! imported_6litrefan General Ford Truck and Excursion 2 01-11-2008 03:01 AM
Frustrated with 04 bforbes 2003-2007 6.0L Power Stroke 16 06-14-2007 08:37 PM
Ubber Frustrated crfracer 1994-2003 7.3L Power Stroke 13 06-26-2006 10:45 PM
