Nut in oil pan - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 377pete, this thread has received 2 replies and been viewed 699 times.
post #1 of 3 (permalink) Old 05-31-2016, 12:00 PM Thread Starter
Nut in oil pan
I have a pete with 3406b. Went to change the oil and found a zinc colored 3/8 nut on the magnetic oil plug. Anyone have an idea where it came from. Thank you
377pete is offline
post #2 of 3 (permalink) Old 06-03-2016, 01:32 PM
SmokinCAT's Avatar
Fine threaded?
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #3 of 3 (permalink) Old 06-04-2016, 12:21 PM
SledMan's Avatar
Like Cody said, is it fine thread? The only places I can think of is a bridge adjusting not, rocker nut or Jake lash nut. The only coarse nuts are on the compressor idler gear and a couple on the front inner cover.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
The Following User Says Thank You to SledMan For this addition to TDG:
Oxbow12 (06-04-2016)
Budd Wheel ::> Cap Nut (Sleave Nut) Torque Spec Victor Medium and Heavy Duty 1 11-05-2014 10:05 PM
Oil Pan rotted out and leaking oil Paintman 2003-2007 6.0L Power Stroke 1 05-06-2010 07:13 AM
I want an old oil pan Zaairman Ford Parts wanted 1 12-10-2009 07:32 PM
Oil Leak at front of oil pan tgr2975 1994-2003 7.3L Power Stroke 6 05-03-2007 01:40 AM
Oil leak behind oil pan Sleepies 1994-2003 7.3L Power Stroke 10 04-27-2006 07:37 PM
