8V92TA stalls at idle sometimes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jjb, this thread has received 22 replies and been viewed 2481 times.
post #1 of 23 (permalink) Old 06-08-2016, 05:25 AM Thread Starter
jjb
I have an 8V92TA in a Military truck that stalls occasionally once warm. I also notice it will run rough at highway speed almost like its not getting enough fuel. It idles very low and sometimes the tach reads 0. At cold start I get about 7-800 rpms.
Any ideas where I should start looking?
Its a military rebuild by Diesel Exchange. It has less than 300 miles on it.
jjb is offline
post #2 of 23 (permalink) Old 06-09-2016, 03:16 AM
Try filters yet?
opus is offline
post #3 of 23 (permalink) Old 06-09-2016, 03:42 AM Thread Starter
jjb
Originally Posted by opus View Post
Try filters yet?
I have them but have been putting it off since its a real pain to bleed. There is no primer pump and the fuel has a long way to go from the tank.
You think it could be that simple? I would think if it was a filter issue it would happen all of the time?
jjb is offline
post #4 of 23 (permalink) Old 06-09-2016, 05:04 PM
Yes, it could still be filters. Are they new filters? Has the engine been sitting for a long time? Excessive smoke...what color?
I didnt know it was doing it sporadically. If you have a 2 stroke DD, you should always have on hand a primer of some sort. Lots of people use a weed spray bottle, some use an electric fuel pump.
opus is offline
post #5 of 23 (permalink) Old 06-10-2016, 04:49 AM Thread Starter
jjb
No excessive smoke. The engine was reman'd in 2010 and I just put it in this truck last year. So it sat for 5 years but it was never run after it was rebuilt.
Not really sporadically. When its cold it seems find but at operating temp it stalls but not always. Usually when I get off the throttle quickly.
jjb is offline
post #6 of 23 (permalink) Old 06-10-2016, 05:08 AM
You know, I think you'll find your best answer to this over at the busconversion.com forum. Those guys are aces with 2 strokes. They take you step by step through diagnosing it.
opus is offline
post #7 of 23 (permalink) Old 06-10-2016, 05:09 AM Thread Starter
jjb
I'll give it a shot thanks.
jjb is offline
post #8 of 23 (permalink) Old 06-10-2016, 05:30 AM
Being a military engine is a non DDEC. That should eliminate electrical issues. I'm still thinking fuel starvation. Dirty air filter would give smoke.
Messed up injector? I'll watch over there for you.
opus is offline
post #9 of 23 (permalink) Old 06-11-2016, 03:17 AM
Whats the oil pressure like?
Les2 is offline
post #10 of 23 (permalink) Old 06-11-2016, 09:24 PM
Oxbow12's Avatar
8v92TA was always mechanical injection, no?
Oxbow12 is offline
8v92ta questions oleblue6banger Medium and Heavy Duty 7 07-24-2011 05:31 PM
Truck stalls crb478 1994-2003 7.3L Power Stroke 13 01-09-2009 03:45 PM
stalls while idle in drive brnofrd 5.9L Cummins 12 Valve (1994-1998.5) 4 06-25-2007 05:57 PM
Drive like Granny=OK, Drive like Earnhardt=stalls at idle GeneralLeo 1994-2003 7.3L Power Stroke 3 09-15-2006 04:39 AM
