Cummins Big Cam help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Four Angels Trucking, this thread has received 4 replies and been viewed 974 times.
post #1 of 5 (permalink) Old 06-22-2016, 12:23 AM Thread Starter
I am building a 79 Mack Superliner with a Big Cam 2 I believe.Here is the serial number on block 10801801 and the CPL is 393.Can someone help me with the CPL and let me know the info on that.Thanks
Four Angels Trucking is offline
post #2 of 5 (permalink) Old 06-22-2016, 10:29 AM
SmokinCAT's Avatar
BC1, rated at 400.
The early 400s have 14.5:1 compression compared to the later 400s at 14:1. If it has the original cam that is different then later 400s as well.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #3 of 5 (permalink) Old 06-22-2016, 02:33 PM Thread Starter
Thanks for the reply.Are these pretty good motors?Im currently running a Pete with a Bmodel with the fuel done and bigger turbo.Can this big cam make just as good power with pump adjustments etc?
post #4 of 5 (permalink) Old 06-22-2016, 06:46 PM
SmokinCAT's Avatar
Big cams are good engines, they preform differently then a B model, you don't lug the BC and need to use the rpm, don't pull it below around 15-1600rpm if you add fuel by either the pump or injectors.
My best suggestion is to have a set of injectors built for it then you can do some pump work to match injectors or have it done by the shop that builds the injectors.
Cody.
4.11 SQHP rockwells
post #5 of 5 (permalink) Old 06-29-2016, 04:08 AM
Really good engines! Some improvements were made along the way such as lower press fit liners. It is hard to find anyone to do that machine work anymore but a good investment if you are going to keep and run it. There were some different liner options along the way so if you go back as it was match replacements to number on old ones. If it has coolant streaks on block from head gaskets plan to have the block cut before even starting.
tenwheeler is offline
Cam Replacement on Big Cam Cummins LOG HAULER Medium and Heavy Duty 3 05-18-2013 05:00 AM
Small Cam/Big cam Cummins LOG HAULER Medium and Heavy Duty 17 04-25-2013 05:33 AM
big cam cummins haymafia Medium and Heavy Duty 15 11-02-2009 04:16 AM
Big Cam Cummins haymafia Medium and Heavy Duty 16 04-29-2009 04:07 PM
Big Cam Cummins chris142 Whats Been Sold 1 12-29-2008 05:08 AM
