Fuel in radiator with a 6NZ - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by franko2me, this thread has received 4 replies and been viewed 1062 times.
post #1 of 5 (permalink) Old 07-01-2016, 04:06 PM Thread Starter
I'm getting fuel in the radiator tank with a 6NZ in it. I read somewhere that it can be from the injectors. But I can't remember, is it the cup seals or the injectors seals? Is that the only way that diesel can get into the antifreeze?
franko2me is offline
post #2 of 5 (permalink) Old 07-01-2016, 05:22 PM
Jasong's Avatar
I think a cracked cup can do that as well.
Jasong is offline
The Following User Says Thank You to Jasong For this addition to TDG:
franko2me (07-02-2016)
post #3 of 5 (permalink) Old 07-02-2016, 01:44 AM
Injector Cups
I know it's not an old Cummins but they would do that with a cracked injector sleeve. Cummings had the tooling to test and replace the sleeve without pulling the head. They could have it in and out for less money than I could put a recon head on, that only covered two cylinders, myself. You might call Cat and ask. Some of the best money you ever spend could be at a good Cat house.
tenwheeler is offline
The Following User Says Thank You to tenwheeler For this addition to TDG:
post #4 of 5 (permalink) Old 07-02-2016, 08:59 AM
Cat Attack's Avatar
Pull all 6 injectors, drain antifreeze, borrow the cup puller tool from a cat guy and pull all the cups, almost guarentee one or more is leaking around hardened up orings and or one is cracked. Id replace them all for all they cost, like $10-14ea. Get new injector holdown bolts and orings to. Use siliglide on cup orings and clean motor oil on injector orings. Flush your coolant system with a good heavyduty coolant system flush and be prepared to blow some radiator hoses and heater hoses if its had fuel in the coolant system long or save yourself the headache and possible motor job from overheating from blowing hoses and change all the radiator hoses now. Up to you. Good luck.
Larry
Cat Attack is offline
The Following 2 Users Say Thank You to Cat Attack For this addition to TDG:
franko2me (07-02-2016), Jasong (07-05-2016)
post #5 of 5 (permalink) Old 07-04-2016, 11:36 PM
Saving members money
You, most certainly have at least one bad injector sleeve. Be sure to note, when you pull the injectors, as to whether there is carbon built up on the outside of the injector. When the injector seats go bad, this allows hot combustion gasses to flow up between the injector and the sleeve. This causes the injector sleeve seals to fail prematurely. I have even seen injector sleeves break off in the head, due to deterioration of the metal, from all of the heat. (Note:I have a tool to remove the broken piece, without pulling the head, if that should happen.) Injector seats can be repaired, while the head is still installed on the engine. Cat will tell you, that you need to replace the head if the injector seats are bad. Not so!
Truck engine machinist is offline
Radiator & Hoses leaking badly v. 2nd Radiator to go bad (95,500 miles) Hellraiser 2008-2010 6.4L Power Stroke 9 08-30-2014 04:04 AM
6nz help lobes1985 Medium and Heavy Duty 1 05-31-2014 04:38 AM
bigger fuel lines and filter head for a 6NZ? propane hauler Medium and Heavy Duty 1 07-02-2012 02:53 AM
diesel fuel in the radiator and resevoir mr5fish 1994-2003 7.3L Power Stroke 1 06-06-2010 05:58 PM
Fuel in radiator overflow??? smokin7.3L 1994-2003 7.3L Power Stroke 3 12-06-2007 05:52 AM
