Help with 2002 DT466 code 525 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by marvelouzone, this thread has received 2 replies and been viewed 941 times.
post #1 of 3 (permalink) Old 07-04-2016, 04:31 AM Thread Starter
Hello all. I have a 2002 international 4300 DT466. Just purchased a few weeks ago, when purchased I suspected a few bad injectors, had 357,XXX on dash, had a miss, hard start w/knock when cold... Had injectors tested 5 out of six where bad.. So i replaced injectors with rebuilt/reman ones. Changed oil, oil filter, and fuel filter
After bleeding fuel system, truck started right up cold, but I noticed it still had a miss, upon trying to drive it, it lacked a lot of power very bad. At this point I didn't have a scanner to scan for codes.. truck continued to start for days, just no power, ordered scanner(nexiq) used servicemaxx to get codes, got dtc 525.. upon reading I noticed that rarely is the idm itself the issue, but normally a wiring/clean power issue.. I checked all the known issues, and noticed that all connectors and fuse holders had been changed or removed all together.. I did find bad battery in the process, and replaced. I have not been able to locate ecm relay. Is it in the fuse box? cec relay?
With KOEO standard test passes, injector test brings up dtc525, if I run that same test with injector harness unplugged at valve cover I get 513 and 514 as expected, but no 525. So my question is should I be looking at injector side of harness for problem, or is it still probably a power issue? When truck was starting I was able to verify that all 6 injectors were firing.. just wondering what I really should focus on? is it possible that IDM was really dying causing my misfire in the first place, and now its really dead and does need to be replaced?
my idm is integrated with em, if it is bad do they sell bottom boards for these models as well?
marvelouzone is offline
post #2 of 3 (permalink) Old 07-04-2016, 05:36 PM
Does this engine have the pass through connector on the side of the valve cover?
Terry
This is from the Navistar web site:
525 ECM Injector driver circuit DTC
ECM cannot supply sufficient voltage to injectors
Engine harness, injector harness or ECM problem
terry_g is offline
post #3 of 3 (permalink) Old 07-04-2016, 08:04 PM Thread Starter
yes it has circle connector for injector harness on side of valve cover
Dtc code list for ih 2002 4300 series.(33,000 gvw) I am Phil Medium and Heavy Duty 4 12-06-2014 10:18 PM
2002 4300 series code question I am Phil Medium and Heavy Duty 3 11-27-2014 04:36 PM
4900 DT466 Code 333 Problems forceten Medium and Heavy Duty 14 04-06-2013 01:03 AM
2002 Ram 1500 CODE P1673 neeltburn General Dodge Discussion 0 06-27-2011 03:39 AM
vin code check 2002 chevy duramax badtrx Duramax 2001-2004 (LB7) 0 04-30-2009 02:58 AM
