3406 B Questions..... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1mad dog, this thread has received 2 replies and been viewed 750 times.
 2Likes
  • 1 Post By 1mad dog
  • 1 Post By Cat Attack
post #1 of 3 (permalink) Old 08-10-2016, 01:45 PM Thread Starter
I'm new to this board and could use a little help. I have an 89 4mg, I was not sure if anyone had been in the fuel screws so I set them as per another guys advice. At WOT, back the screws off until they are not contacting the rack bar. turn the fuel screw in until it bare contacts the bar and lock it down. Turn the torque screw in until it barely contacts the bar and then go another 1/4 turn and lock it down. That greatly improved the truck, however I have since then turned them BOTH in round and half (TOO MUCH FUEL). It runs great but the EGT's will climb a little more than I like on a load. I had an old timer turn the timing up a little prior to the fuel adjustment. I think the timing needs to be revisited to help lower the EGT's.....Opinions?
Cat Attack likes this.
1mad dog is offline
post #2 of 3 (permalink) Old 08-11-2016, 03:38 AM
Cat Attack's Avatar
Need to get rid of the stock turbo and replace it with a wastegated 177148 borgwarner 550 C15. Turbo or even a OR-6051 cat turbo. But yes too much timing or not enough is bad. Should have it meter timed to 20-21@ 1000rpm and it should be 30-32@ 1900rpms.
Jasong likes this.
Larry
Cat Attack is offline
post #3 of 3 (permalink) Old 08-12-2016, 02:30 AM
379Longhood's Avatar
If you turned the screws clockwise (IN) that is less rack travel, thus less fuel, maybe enough less to not spin the antiquated turbo up to make enough air flow to keep things cool, and the scroll action adds a tiny bit of timing too. the more efficient turbo form the 550 should improve things, exhaust temp wise. and DON'T let some "expert" tell you to block the waste gate on the newer turbo.
there is a thread by oldnotslow about the turbo swap, oil line mods and his experience with the 177148.
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
The Following User Says Thank You to 379Longhood For this addition to TDG:
Oxbow12 (08-12-2016)
3406 7fb turn up questions? b14 Medium and Heavy Duty 1 08-01-2014 04:20 PM
3406 b model questions logtrucker Medium and Heavy Duty 18 01-26-2012 07:43 AM
Couple of 3406 E questions, any help?! dp90sled Medium and Heavy Duty 6 09-07-2011 06:19 AM
More 3406 e questions dp90sled Medium and Heavy Duty 5 12-03-2010 06:21 AM
3406 questions dracor85 Medium and Heavy Duty 16 03-10-2010 06:42 PM
