3406 7FB No power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by El20, this thread has received 2 replies and been viewed 685 times.
post #1 of 3 (permalink) Old 10-08-2016, 02:45 PM Thread Starter
3406 7FB No power
Thanks to all in advance;
I just replaced a cyl hd on this old 7FB do to a small bolt left in #5 intake port, looked like it had been there for a very long time and finally wore down to lodge its self in valve and bent it. This engine is suppose to be a 310 hp the piston number are 9Y3116 what will be the best nozzles i can use to make it a better running engine. i will also be changing the turbo with one from a 3406E that i have on a block that thru a rod. Your info will be highly appreciated.
El20 is offline
post #2 of 3 (permalink) Old 10-11-2016, 07:55 AM
Cat Attack's Avatar
Your serial # and or arrangement # would help determine what pump cam it has and what it should be timed to.
Larry
Cat Attack is offline
post #3 of 3 (permalink) Old 10-11-2016, 08:19 AM
Cat Attack's Avatar
Going by the piston number you gave its 15.2:1 compression with a high top ring location and is for 310hp or lower. You dont know what nozzles are in it currently do you?
Larry
3406 7FB Build perrykit Medium and Heavy Duty 8 05-28-2015 04:27 AM
3406 7fb turn up questions? b14 Medium and Heavy Duty 1 08-01-2014 04:20 PM
3406 280hp looking for more power scott11674 Medium and Heavy Duty 5 04-08-2013 03:15 AM
3406 B 7FB fuel shut off solenoid? Suffacated Medium and Heavy Duty 15 02-18-2011 05:43 AM
3406 no power dragracer Medium and Heavy Duty 27 03-21-2010 05:00 PM
