3406b exhaust temps too high - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Vindicator240, this thread has received 12 replies and been viewed 1634 times.
post #11 of 13 (permalink) Old 07-06-2018, 04:21 PM
oldnotslow's Avatar
Vindicator, I am curious if you found the cause of this?
oldnotslow is offline
post #12 of 13 (permalink) Old 06-07-2019, 04:59 PM Thread Starter
Vindicator240's Avatar
Sorry it’s been so long, the cause was that the fuel was turned up too high previously and with the bigger nozzles it made it that much worse
Jeremy
Vindicator240 is offline
post #13 of 13 (permalink) Old 06-15-2019, 11:08 AM
The other guy
Originally Posted by Vindicator240 View Post
Sorry itís been so long, the cause was that the fuel was turned up too high previously and with the bigger nozzles it made it that much worse
Unless structeral failure or bowl quench is reached in fuel delivery, which for a DITA mechanical Cat is around 2200HP unmodified for flow, there is no such thing as too much fuel. It's timing. The original nozzle number, 0R3424, is really only used in early PEEC engines. Converting a PEEC to mechanical it is easy to miss something on, plus timing needs compensated for a different rise rate in the advance and a slower valve cam. 19* @ 1000rpm with the start screw at 1260rpm and no stop screw. Also your replacement nozzle is a 3423 not a 3421. 3421's are for 14.5 piston bowls and 3423's are for 15.2's. Most likely the advance spool is'nt coming up so you're not getting actual advance. That's the only way you can move timing all around and have no change. If the advance is working right there's kinda no way you didn't get real close one of the times.
ynot is offline
Cummins ISX low boost high exhaust temps bucko149 Medium and Heavy Duty 26 12-18-2015 05:12 PM
04 F250 6.0 High Exhaust Temps rpmmmm 2003-2007 6.0L Power Stroke 23 07-23-2011 05:57 AM
High fuel temps? bigpete 2008-2010 6.4L Power Stroke 4 07-15-2011 11:34 AM
exhaust temps, 3406b snowman_w900 Medium and Heavy Duty 5 07-28-2010 04:31 AM
High Exhaust Temps Pittsburgh-05HD 2003-2007 6.0L Power Stroke 17 07-31-2006 10:00 PM
