2001 kenworth Caterpillar 6nz turbo lag - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GTCooper, this thread has received 10 replies and been viewed 1899 times.
 1Likes
post #1 of 11 (permalink) Old 04-11-2018, 10:05 PM Thread Starter
GTCooper's Avatar
I have serious turbo lag. Going down flat highway, 65mph, 5psi of boost. Step into it and it takes 15 seconds to go from 5 psi to 15 psi. And has a max of 20 psi. I don't remember it being this slow to build boost. Only thing I physically see is the joints on the exhaust manifold. One of them I can turn the metal band and clamps. Don't see any soot though. Any thoughts? Things to check?
Sent from my SM-N950U using Tapatalk
GTCooper is offline
post #2 of 11 (permalink) Old 04-11-2018, 10:40 PM Thread Starter
GTCooper's Avatar
Forgot to mention, borg warner turbo with gate.
GTCooper is offline
post #3 of 11 (permalink) Old 04-13-2018, 04:23 PM
Ol Dirt Contractor
Lowboy's Avatar
I'd be seriously looking at possible gate or turbo malfunction... No leaks or soot showing points right back to the turbo.. Make sure there is no restriction out to the stack..
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
post #4 of 11 (permalink) Old 04-16-2018, 06:42 AM
Jasong's Avatar
I agree, sounds like the waste gate isn't closing correctly.
Jasong is offline
post #5 of 11 (permalink) Old 04-21-2018, 10:04 PM
oldnotslow's Avatar
Charge Air cooler leaking? Hoses or boots to or from Charge Air Cooler leaking? Your symptoms are almost identical I had on my 3406B CAT. Tiny crack about 2" long in top row of my Charge Air Cooler. Took forever to find it. Problem solved.
oldnotslow is offline
post #6 of 11 (permalink) Old 04-21-2018, 10:54 PM Thread Starter
GTCooper's Avatar
Replaced hoses and clamps this past Monday while at home. Seemed to help a little. Going to change the wastegate and test cac when I get back in, Monday or Tuesday. I'm thinking that's what it will end up being is the cac.
GTCooper is offline
post #7 of 11 (permalink) Old 04-22-2018, 04:08 PM
oldnotslow's Avatar
I also had a hole in my CAC about 5 years ago. Repaired it with JB Weld. It was still holding solid this year when the crack appeared and I replaced the whole thing. FYI
GTCooper likes this.
The Following User Says Thank You to oldnotslow For this addition to TDG:
GTCooper (04-22-2018)
post #8 of 11 (permalink) Old 04-22-2018, 05:03 PM Thread Starter
GTCooper's Avatar
Yeah. If it doesn't pass the leak down test, I'm just going to replace it. Looks like the original 17 years old.
GTCooper is offline
post #9 of 11 (permalink) Old 04-23-2018, 09:53 PM Thread Starter
GTCooper's Avatar
Well doing some checking and trying to replace wastegate, and wouldn't you know it. One of the bolts broke off in the housing. Also discovered an exhaust leak where down pipe meets turbo. Would that cause an issue?
GTCooper is offline
post #10 of 11 (permalink) Old 04-24-2018, 02:16 AM Thread Starter
GTCooper's Avatar
And the charge air cooler will hold no pressure.
GTCooper is offline
2001 kenworth w900l cab heater breaker GTCooper Medium and Heavy Duty 3 07-17-2016 02:12 AM
cm 871 turbo questions turbo lag tinystrucking Medium and Heavy Duty 8 04-28-2014 12:46 AM
Engine swap, 1LW to 6NZ....Western Star chassis to Kenworth T-800 teeroy Medium and Heavy Duty 38 04-01-2012 05:28 AM
turbo lag elkhunterr81 2003-2007 6.0L Power Stroke 10 03-28-2010 06:34 PM
turbo lag? Lurkin 2008-2010 6.4L Power Stroke 10 04-19-2009 05:47 PM
