04 international 4300 dt466 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tonyt22, this thread has received 1 replies and been viewed 482 times.
post #1 of 2 (permalink) Old 07-04-2018, 12:32 AM Thread Starter
Is the 04 4300 a dependable truck I know the later maxforce engines are bad along with the dt466E but is the 04 good to go ? Shop is saying it's a dt466 how can I tell the difference between the regular and E variants
Tonyt22 is offline
post #2 of 2 (permalink) Old 07-07-2018, 05:39 PM
Super Moderator
nevrenufhp's Avatar
04 is a break year. The early one is the typical E. The later 04 is the newer style used up to 08. Bonus being, the newer one can use the Hypermax performance module. Bonus with the older one is being able to convert back to mechanical if you were looking for ultra reliability with power potential. Not that they were that bad, it's just an option. Quick fix on the newer gen is to block off the EGR.
Easy way to tell the difference between the 2 generations: Newer one has EGR crossover tube wrapping around the front of the engine. It's about 1.25-1.5" OD.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
DT466 04 Int'l 4300 cooling issue ashill4413 Medium and Heavy Duty 18 08-18-2014 12:25 PM
2006 dt466 4300 starts and runs for 5 mins patricks Medium and Heavy Duty 0 01-08-2012 03:15 PM
Need help with '06 Int'l 4300 w/ DT466 bebop Medium and Heavy Duty 4 09-08-2011 12:07 AM
07 Int. 4300 w/DT466, died NO start - HELP! snaganddrag Medium and Heavy Duty 5 07-12-2011 05:25 AM
2004 International 4300 dt466 Frankiep02 Medium and Heavy Duty 3 01-01-2009 03:31 PM
