Lost stud & nut from rear hub on rear axle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Duke, this thread has received 4 replies and been viewed 1720 times.
post #1 of 5 (permalink) Old 08-07-2005, 02:35 AM Thread Starter
'Ol Builder guy
Duke's Avatar
I was running my IH a lot yesterday and noticed a hole in my hub where there's supposed to be a stud screwed in and a nut on the end of the stud.
Not a lug nut, but one that holds the cap & seal on the end of the axle hub.
OK to keep driving? I would think it'll be fine. It's not losing any oil since the seal is still tightly in place.
Also, on my other rear wheel, there's a "spray" of grease/oil spots around the circumference of the budd wheel. Does this mean the hub seal is shot?
Duke is offline
post #2 of 5 (permalink) Old 08-07-2005, 02:38 AM
With all of the bolts on the end of that axle you should be fine duke..I'd find a new bolt for it sooner than later though....
and yep, sounds like you have a seal leaking on the other side..
partsguy662 is offline
post #3 of 5 (permalink) Old 08-07-2005, 01:45 PM Thread Starter
'Ol Builder guy
Duke's Avatar
OK, just as I thought. Thanks for the back-up!
Scary when you lose something like that off your truck. You hope it hasn't damaged anyone's car!!
Duke is offline
post #4 of 5 (permalink) Old 08-07-2005, 02:18 PM
Unless they are tailgateing you....then you hope it goes through their radiator
post #5 of 5 (permalink) Old 09-18-2005, 06:31 AM
International Tech.
Hmmm, sounds like you found out why your axle flange was leaking...
Some of them had issues with this. Get some new studs and nuts and GREEN loctite. They will be in there for a while
2003EDGE is offline
Hurricane Survival Kit TriGuy The Parking Lot 7 10-24-2005 01:47 AM
AIRAID Intake AUGSX Supporting Vendors Forum 3 10-17-2005 11:11 PM
