95 fld120 series 60 a/c and cooling fan? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jsnap, this thread has received 4 replies and been viewed 1127 times.
post #1 of 5 (permalink) Old 04-16-2008, 02:00 AM Thread Starter
Can someone please tell me if the cooling fan is supposed to come rite on when the a/c is on. I was under the impression it was supposed to regardless of engine coolant temp. I thought once the a/c was switched on the cooling fan was suposed to engage to pull heat of the a/c condensor the reason i ask is that my fan does not come on when the a/c is on. So am is my fan working rite or is something wrong thanks in advance .Richie
jsnap is offline
post #2 of 5 (permalink) Old 04-16-2008, 02:05 AM
There is a switch in the high side of the AC system. It should turn the engine cooling fan on somewhere around 275psi.
chris142 is offline
post #3 of 5 (permalink) Old 04-16-2008, 02:11 AM Thread Starter
Maybe the high side didnt get that high its not really hot out yet i wont worry about it yet i thought once the compressor engaged the fan would go on thanks Chris.
jsnap is offline
post #4 of 5 (permalink) Old 04-16-2008, 02:14 AM
you need to put some AC guages on it to make sure that the switch is working properly.
But no the fan does not automatically come on when the AC is on..........Imagine how much fuel that would use!
chris142 is offline
post #5 of 5 (permalink) Old 04-16-2008, 03:36 AM
The hi pressure is on the dier and is called fan switch by freightliner and there is also a low pressure clutch switch on the dier. most FLD 120 will have a manuel fan switch inside.
theakerstwo is offline
