8.3 Cummins Headgasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acesneights1, this thread has received 3 replies and been viewed 3910 times.
post #1 of 4 (permalink) Old 02-20-2009, 01:14 PM Thread Starter
acesneights1's Avatar
I'm going to have to do one soon. It's leaking down the side of the block. How hard is it ? Anything tricky ? Any special tools required ? Not familiar with these engines. Valve train mech or hyd ? Also is the gasket one piece or multiple ? New headbolts or reuse old ones ?
Thanks
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #2 of 4 (permalink) Old 02-20-2009, 09:18 PM Thread Starter
Originally Posted by ynot View Post
One piece, no tricks, all mech (tru 8.3 P series), no trick tools, old head bolts unless rusted to pitting (or comes in Kit [i.e. aftermarket]), easiest one you'll ever do (cept maybe a 466IH).
That's what I want to hear. Just bagged a service manual off Ebay for 93 series L so hopefully it will have specs for valve adjustment. If not the guys over at the Stealership are pretty good to me(since I support the place so well with my never ending parts bill) so I can probably get it from them. I have only done headgaskets on large diesels twice. ONe was a 6v53 which I still have nightmares from and the other was a 285 Mack which IIRC was a PIA too with the fire rings . Thanks.
post #3 of 4 (permalink) Old 02-21-2009, 12:52 AM
bmoeller's Avatar
VERY easy job, as the engine goes. Hopefully you don't have a bunch of crap in the way.
May not always be necessary, but I always replace the head bolts. At least ones with high hours or miles. Just piece of mind.
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 4 (permalink) Old 02-21-2009, 04:49 AM
Just remenber that there is some head bolt under the injectors. The injectors have to come out to get to them. I saw a know it all mechanic all most had the front wheel off of the ground trying to pick up the head. He ask if i thought he should drive a screw driver between the head and block and i said no but pull the injectors and see what is under them.
theakerstwo is offline
Blown Headgasket????WTH danster 2003-2007 6.0L Power Stroke 11 02-13-2009 01:53 AM
Blown Headgasket / Bolt/Stud Combo Poll smiley1 2003-2007 6.0L Power Stroke 22 01-02-2008 02:29 AM
headgasket job need help!!! 04-F350 2003-2007 6.0L Power Stroke 4 04-25-2007 03:08 AM
puking always means headgasket? ncbowhunter 2003-2007 6.0L Power Stroke 18 03-13-2007 11:49 PM
hypermax headgasket?/Puking tedshields 2003-2007 6.0L Power Stroke 20 08-14-2005 06:43 PM
