3176B CAT not revving well what do I do? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by S-AOW, this thread has received 10 replies and been viewed 3116 times.
post #1 of 11 (permalink) Old 08-30-2009, 09:16 PM Thread Starter
Guys I've got a Freightliner FLD120 with 3176B CAT engine double axle, 3.65 gear ratio, 365HP, not revving to more than 1500rpm while on motion and will only exceed that going down hill. But when traveling uphill, it gets below 1500rpm to as low as 1000rpm even when the throttle is floored.
What could be the problem? We have replaced the air filter, done the oil change (even when its only done 9,850Miles since the last oil change) change the oil & gas filters.
Please what's the correct thing to do or what next should we do?
Thanks
S-AOW is offline
post #2 of 11 (permalink) Old 08-30-2009, 09:48 PM
bmoeller's Avatar
From reading your other threads, is this one of the trucks with the chk eng light flickering? Almost sounds like limp mode.
What is the fuel pressure?
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 11 (permalink) Old 08-30-2009, 09:55 PM
check fuel supply line ,inner liner collapses restricting fuel supply
Bob
burkeftm is offline
post #4 of 11 (permalink) Old 08-30-2009, 10:02 PM
The other guy
Thanks
!!! Another good call bud!!
ynot is offline
The Following User Says Thank You to ynot For this addition to TDG:
bmoeller (08-31-2009)
post #5 of 11 (permalink) Old 08-31-2009, 11:24 PM Thread Starter
Nope this isn't the one with the CHK ENG light. This one is about a thousand miles away from me. The driver complained about the low rpm last nite. Hope to get ideas for fixing it before it gets back to base. Pls pardon my ignorance, what is "limp mode"?
S-AOW is offline
post #6 of 11 (permalink) Old 09-01-2009, 12:33 AM
bmoeller's Avatar
Limp mode basically protects the engine when something is wrong. It limit RPMs or hp output. Could possibly shut the engine down if need be. Have seen some equipment that have an over ride switch to keep it running to get to the shoulder. You have to push and hold it.
Electronically controlled transmissions can do the same. They will limit what gears can use going forward, and allow rev only.
Can the driver get it to a shop with a computer to hook it to? Could maybe be a cam or crank position sensor causing the problem.
Any chance of having an automated transmission?
bmoeller is offline
post #7 of 11 (permalink) Old 09-01-2009, 03:17 AM
The other guy
Regardless of light (which can blow or glitch etc...), if he's at a standstill and mashes it to the floor and it hits 1500 and stops like a wall, it's limp mode. If it flutters or bounces around 15/ 1600 or whatever, you'll hafta ET the TPS, which doesn't always set the light or even code, tho should definately in limp mode. Key off and on to check if the light works
ynot is offline
S-AOW (09-01-2009)
post #8 of 11 (permalink) Old 09-01-2009, 07:00 AM Thread Starter
The lights doesnt come on. Please what do you by " you'll hafta ET the TPS" ? Please once again bear with my massive ignorance. Then also what do you think about the truck doing the trip back (it's kinda roughly a thousand miles away from base) before we fix the problem?, cos essentially we might not get anywhere it could do a proper diagnosis along the way!
Thank you immensely
S-AOW is offline
post #9 of 11 (permalink) Old 09-01-2009, 01:00 PM
bmoeller's Avatar
The TPS is the throttle position sensor.
The ET is one of Cat's electronic diagnostic tools. Can see some of what is going on, and also change some parameters.
You should be able to test it with an oscilloscope as well. Can watch the bandwidth as you move the throttle. You'll be able to see any place there is a problem within its travel. As you move the throttle slowly one way or the other, it show a steady increase or decrease without it jumping around if it is OK.
bmoeller is offline
post #10 of 11 (permalink) Old 09-01-2009, 03:59 PM
The other guy
Thank you immensely
Not a problem. If it was in immanent danger, it would shut down. It'll make it home (slowly )
Thanx again Bri. I hafta remember we're not all from here, or able to speak Texan...
ynot is offline
bmoeller (09-02-2009)
Cat 3176B tdubovsky79 Medium and Heavy Duty 10 10-28-2007 03:34 AM
