C-15 injector trim codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4xtim, this thread has received 13 replies and been viewed 32582 times.
post #1 of 14 (permalink) Old 11-26-2009, 05:45 AM Thread Starter
Just in-framed a C-15 at work (my first cat rebuild). Has anyone ever ran into having brand new re-man injectors right from CAT not having the 12 digit code needed for the trim files. There was only a 7 digit and also a 4 or 5 digit code on the top of the solenoid body that I had written down before install. WTF. Cat dealer is stumped. They said that they'll send me new injectors and credit me for the others-Great!!???? I have the whole thing done and buttoned up. '06 MXS serial. 10R-7174? injector PN which each came with a cd that has like 100 + files to choose from. I pulled off 2 of the valve covers for another look. No numbers on the side of the white plastic solenoid, nothing on the top spring pad, nothing on the smooth polished metal ring on the injector body just below the solenoid. Nothing. Looks like I get more practice adjusting valves, injectors, jakes, and intake valve actuators on a c-15. Most time consuming top end adjustment I've done yet. Oh well, I'm having fun though. Engine seems to run fine. Whats the worst that can happen by not having the correct trim codes programmed in the ecm?
'06 F-250 CC SB, lifted 10.5 Rize Industries, 38" Nitto Muds on 20" Moto Metal 951, Bilstien 7100 reservoirs, Fabtech Dirt Logic 2.0 Steer stabs with Rize bracketry, MBRP 4" turbo back cool duals- no muff or kitty, CCV mod, coolant filter kit made by me, rest of 6.0 stock for now.
4xtim is offline
post #2 of 14 (permalink) Old 11-26-2009, 01:21 PM
SledMan's Avatar
Cat will swear the trim codes are for idle quality. Personally I've never had them make a difference in idle, but certain codes will give a little more power on non-Acert applications. Not sure for Acert though.
SledMan is offline
post #3 of 14 (permalink) Old 11-26-2009, 04:42 PM
03cmmns's Avatar
that is weird...usually the remans have a metal ring around the solenoid so like you said and the numbers could be on that or by the two posts that your inj harness hooks to. Like sledman said they are usually just for idle smoothness...you should be fine.....i've never tried on the newer ones but like the older 5EK engines you can change the codes and get some more power
03 2500 Ram 4x4 Reg Cab-Diablo Sport Predator/Puck,BHAF,Isspro Pyro,Boost,Trans Temp,Fuel Psi,HTS Race Build Tranny, Suncoast Converter,Silverline Exhaust,BD Lift Pump, 3/8" Fuel Line, Homemade Filter Setup,free mods.
03cmmns is offline
post #4 of 14 (permalink) Old 11-28-2009, 02:58 AM Thread Starter
MMMMMMM, interesting info. New injectors were ordered up. Hopefully they all have a good 12 digit # on them to use. Is there any bulletins on Cat SIS on anything about trim codes so I can learn more?
4xtim is offline
post #5 of 14 (permalink) Old 11-28-2009, 01:11 PM
dds
dds's Avatar
Trim codes are result of injector calibration, All injectors flow different cc rates. The trim does affect idle but also across the whole fuel map. If you play with trim codes, I have got over 50 hp wheel difference of the dyno. The best is to have your injectors flow tested and then have the trims matched to the max ecm value of the injectors installed, you will have a smooth idling and pulling engine with 40 to 50 hp ore than stock.
dds is offline
post #6 of 14 (permalink) Old 11-29-2009, 01:15 AM
PB SHOP FOREMAN
domniman2002's Avatar
we have sent them down the road without changing the trim files, you will have to go in and correct this if the customer comes back with a low power complaint or rough idle issue. usually if you go to truck.cat.com you can put that number in and it will tell you the sixteen digit number. if not on the disc you can download straight from that site. givin you have a cat sign on.......if not.....let me know and send me the number and i can send you the trim file that you need. jon
SHOP FOREMAN FOR PETERBILT IN THE GREAT STATE OF TENNESSEE.....28YRS JOURNEYMAN TECH
domniman2002 is offline
post #7 of 14 (permalink) Old 11-29-2009, 03:39 AM Thread Starter
Will my password for SIS work on that site or is that a different subscription? I'll have to check it out on Monday. I don't work for a Cat certified dealer. I'm a diesel mechanic for a private company. So your saying that I can use the 7 digit and 4 or 5 digit #'s to get a 12 digit # to select from the list of trim codes on the cd's that came with the new injectors? Just trying to learn as much as I can here and do things right.
4xtim is offline
post #8 of 14 (permalink) Old 11-29-2009, 07:22 AM
There's your problem.
Send a message via AIM to Dutch
You need the all full injector number to get the correct trim file for the injector.
Dutch is offline
post #9 of 14 (permalink) Old 11-29-2009, 03:13 PM
PB SHOP FOREMAN
im saying that if you have password to get onto sis that you can go to the bottom right side corner where it says files and software and find what you need, then download onto a flashfile and take it out to the truck and download into the ecm. your sis password should work. jon
The Following User Says Thank You to domniman2002 For this addition to TDG:
dieselone (05-03-2010)
post #10 of 14 (permalink) Old 11-30-2009, 04:31 AM Thread Starter
Ok thanks. I'll check it out this week. I hope I can do some good with the numbers that are on these new injectors that are installed already. Just stumped why they dont have the 12 digit code on them.
4xtim is offline
Injector Circut Low Codes...FICM??? Bane 2003-2007 6.0L Power Stroke 3 06-19-2009 02:54 PM
Trim Slim_33 5.9L Cummins (2003-2007.5) 4 12-30-2008 05:21 AM
Plastic trim pieces/painted trim for 05-07 bumpers DEERSNIPER Whats Been Sold 0 05-02-2007 12:59 AM
EX dash trim vs. F250 dash trim? sredish 2003-2007 6.0L Power Stroke 13 06-15-2006 03:29 AM
injector codes fordfanatic69 2003-2007 6.0L Power Stroke 9 03-19-2006 11:30 PM
