extra air cleaner on a pete - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aggar, this thread has received 4 replies and been viewed 1671 times.
post #1 of 5 (permalink) Old 01-28-2010, 07:07 PM Thread Starter
aggar's Avatar
I'm wanting to add an extra air cleaner on my 378 to even it out. Not really wanting it functional just so it doesn't look weird. Are there any mounting kits out there available for this? I've found a cleaner on Ebay just like what is already on the truck. Thanks.
2006 ccsb LBZ Not so stock
2001 ECLB LB7 Stock
aggar is offline
post #2 of 5 (permalink) Old 01-28-2010, 08:25 PM
379Longhood's Avatar
If the aircleaner has brackets you just need to buy some nutsserts and and drill the appropriate holes the rest of the ducting can come from a wreckers if you want or hinge the top and you've got a handy light weight stuff box
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #3 of 5 (permalink) Old 01-29-2010, 02:50 AM
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
shouldnt be too hard to make it functional either if you can find a wrecked pete with all the ducting and brackets..two birds with one stone...functional and looks good
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #4 of 5 (permalink) Old 01-29-2010, 02:52 AM
Paccar Cat Nothing Else's Avatar
If you do go with two functional air cleaners, the air filters will last WAY longer. Honestly, the air cleaner is the most expensive part. After that, the rest shouldn't be too bad.
Paccar Cat Nothing Else is offline
post #5 of 5 (permalink) Old 01-30-2010, 01:48 AM
TDG Singles Club #112
cummins_cowboy's Avatar
What Did I DO?
Send a message via Yahoo to cummins_cowboy
The drivers side breather on my Pete (in my sig) is not functional. The ducting stops right inside the hood. It is a little rough up close, but looks pretty good from a ways off.
Early 99 F-350 4wd SC LB Lariat 7.3/ZF-6
S&B Air Box,4in dp, 5 inch straight pipe
DP F5 with hi idle, 60 tow, 80 econo, and 120 race
SS HPX line, ITP Overboost Annihilator, CCV mod
1995 Pontiac Formula Firebird LT1/6spd
1977 Chevrolet K-20 4spd
1973 Peterbilt 359 Big Cam/ 13spd
1989 Peterbilt 379 Long Hood B model/13spd 22' Mid-America Combo Box
1985 Peterbilt 359 Big Cam / 13spd
cummins_cowboy is offline
86 359 pete ktw900 Medium and Heavy Duty 11 11-18-2009 11:37 PM
'06 379 Pete dash pullingtrucker Medium and Heavy Duty 3 08-25-2009 01:42 AM
377 Pete /444 stc info Tyrod Medium and Heavy Duty 9 05-12-2009 12:41 AM
Fullsize Pete cab on CTD hvy 1ton 5.9L Cummins (2003-2007.5) 2 10-30-2006 03:06 AM
ads I found:Pete 359 cab, DD 4-53, & more nevrenufhp Whats Been Sold 0 01-21-2006 03:27 PM
