fuel pump problems
installed the raptor 150 yesterday and the truck started fine and had 30 psi + of fuel pressure, it ran for about to mins and then died, could get it started for a few seconds then died again, i called tech suport and the guy told me that it was more then likley the lift pump in the tank, i looked on my motor and did not see a lift pump, so he told me to order a draw straw kit and it should fix it. when i took the filter cap off and ran the pump, it would spit a lil bit of fuel then air, i bleed all the lines, will the draw straw fix it or could there be any other problems, need help asap!!!!! thanks
97 f 250 xlt 4 inch lift, 36/15.50 tires, hypermax kit with sledghammer turbo, swamps 355mm injectors, compitition fuel system,bdp stealth pumps oil system, head studs, custom 4 inch exhaust, edge evo and ez stack
