air compressor for a 5.9 cummins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hayjayhorses, this thread has received 2 replies and been viewed 7932 times.
post #1 of 3 (permalink) Old 10-04-2010, 05:23 AM Thread Starter
hayjayhorses's Avatar
I am putting a cummins 5.9 12v in my GMC top Kick and i want to put an air compressor on the engine with the big hydraulic pump on the back of the air compressor
I am looking for air compressor part # and hydraulic pump part #
thanks
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #2 of 3 (permalink) Old 10-17-2010, 04:10 PM
Super Moderator
nevrenufhp's Avatar
I dont have numbers, but look at the 8.3 for what you're needing. They share the same bolt ons for compressors and pumps, etc as the 5.9. You could even bolt the big air compressor to a 4BT. Just make sure you get any support brackets for the rear. They break the timing case after a while.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #3 of 3 (permalink) Old 10-17-2010, 04:37 PM Thread Starter
I got an air compressor and hydraulic pump set coming, It is a small air compressor and the big hydraulic pump off of a motor home that had juice brakes and air ride.
As for the rear bracket I will build something, thanks
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
6.0L a/c compressor 6L strokin Ford Parts wanted 2 04-27-2010 02:44 PM
An Air Compressor to Never Own!!! Les2 Medium and Heavy Duty 11 01-10-2010 07:01 PM
ISX Air compressor legend10 Medium and Heavy Duty 4 10-17-2009 04:22 AM
N14 Air Compressor imported_ESJDIESEL Medium and Heavy Duty 6 02-12-2007 10:38 PM
HELP!! Removing a Cummins air compressor. chris142 Medium and Heavy Duty 16 12-23-2006 10:40 PM
