Looking for some info - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 9 replies and been viewed 1049 times.
post #1 of 10 (permalink) Old 12-14-2010, 03:40 AM Thread Starter
vcassens's Avatar
I am looking for any and all info on swapping a 4bt into a 98 chevy s10 blazer I have looked but cant find anything. Has anyone seen or swapped one into a s10 or s10 blazer thanks
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 10 (permalink) Old 12-14-2010, 03:44 AM
I feel sure it can be done, after all they put them in jeeps.
later is offline
post #3 of 10 (permalink) Old 12-14-2010, 04:58 PM Thread Starter
vcassens's Avatar
Ya I am sure it can be done just looking for parts like trans adapters and what not
singles club #206
bomb squad #67
vcassens is offline
post #4 of 10 (permalink) Old 12-14-2010, 11:32 PM
Pardue the Traveler
New 0mega's Avatar
Destroked has trans adapter plates
http://www.destroked.com/parts/adapter_plates.shtml
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
vcassens (12-15-2010)
post #5 of 10 (permalink) Old 12-15-2010, 06:13 PM Thread Starter
vcassens's Avatar
So do the 4bt and the 5.9 use the same adapter plates?
singles club #206
bomb squad #67
vcassens is offline
post #6 of 10 (permalink) Old 12-15-2010, 07:43 PM
Pardue the Traveler
New 0mega's Avatar
As far as I know. The 3.9L is basically a 5.9L with two cylinders lobbed out of the middle.
post #7 of 10 (permalink) Old 12-15-2010, 10:24 PM
Correct, Many of the delivery vans that had 3.9 in them use a turbo 400 automatic transmission if it was a GM van body. Check with some of the guy that part them out and you could go that rout but I would think the RE47 or RH47 would be a better choise. That will just depend on how much power you are looking for.
later is offline
post #8 of 10 (permalink) Old 12-15-2010, 11:01 PM Thread Starter
vcassens's Avatar
Ok I will give a quick run down on what I am wanting to do when I can. The wife and I have a 98 chevy blazer it is her daily driver and when it is paid off we are going to look into getting something else for her and I am wanting to put a 4bt in it. I am not looking for a big power house I will be keeping the IFS for ride quality and I am looking for good millage if possible I no nothing about these little motors. The blazer will become my daily driver and hunting rig nothing crazy on power for now just a fun little vehicle to drive and get good millage I have the truck for the crazy . I also have no idea what trans is in the blazer so that info wold help also thanks
singles club #206
bomb squad #67
vcassens is offline
post #9 of 10 (permalink) Old 12-16-2010, 01:12 AM
Does the blazer have a 4 or 6 cylinder? A 4.3 V6 gas motor can make very good power.
You do realize that a 3.9 or a 5.9 is taller and may not fit that easy. I have seen a 3.9 in a Dodge D50 but the guy just took the sheet metal and put it on a 1st gen rolling chassie after he shortened the frame. He had to add block between the frame and the body mounts and it was ok but why not just trick out a Standard Cab Long bed into a SCSB? If you are wanting a lighter vehicle then start with a 1500 SCSB. Think about it unless you are willing to spend many hours doing hard work that will not return all you spend on it. And just think about trying to find parts.
later is offline
post #10 of 10 (permalink) Old 12-16-2010, 06:24 AM Thread Starter
vcassens's Avatar
I see what you are saying but I like a challenge . I want to do the blazer because it wold be different and I want a diesel in it for the millage it wont be a big power house and as far as the height of the motor I wold not be against a body lift and a custom hood. The blazer as it sits now has a 4.3 in it and does great as far as power and getting it done goes I just want something different.
Thanks for the ideas and advice guys keep them coming this project is still at least a year or 2 off but it never hurts to start researching early
singles club #206
bomb squad #67
vcassens is offline
need info Van 250 newbe-ken Duramax 07.5-2010 (LMM) 1 11-14-2007 12:17 AM
Info Please WEDale Ford Oasis requests 0 09-18-2007 03:29 PM
SCT info barry1me 2003-2007 6.0 Tuner Forum 18 05-31-2007 09:02 PM
VSS Info ymmot 2003-2007 6.0L Power Stroke 3 02-16-2006 08:21 AM
TSB info EPDP99 2003-2007 6.0L Power Stroke 4 02-06-2006 09:47 PM
