DIESEL SUBURBAN - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 67c10, this thread has received 4 replies and been viewed 2501 times.
post #1 of 5 (permalink) Old 02-13-2011, 07:59 PM Thread Starter
DIESEL SUBURBAN
I have a 99 chevy suburban k1500 im looking 2 get a diesel for it
im looking for good mpg
can tow a lot
and has a good amont of get up and go
what motor shoud i look for
thank you
67c10 is offline
post #2 of 5 (permalink) Old 02-13-2011, 10:53 PM
If I wanted major towing ability and decent fuel economy I'd look for a Cummins 12 valve between '94 and '98. You didn't mention whether this is a 4x4 and what transmission you have. You would probably have to update the transmission and maybe change rear gears. These engines tend to be the least complicated to hook up although there can be some areas where fitting it in gets a bit tight. That is a heck of a big six and it weighs about 1100 lbs. I've seen several installs with that engine on other forums that turned out very nice. You might want to look at some on 4bt swap. Several guys there have done chevy suburbans and pick ups. Takes a bit of work but can be done. You could alway go with a duramax but the electronics would definitely be more complicated.
char1355 is offline
post #3 of 5 (permalink) Old 02-13-2011, 11:49 PM Thread Starter
i have a 94 12v in my shop right now i would love to get it in thar but i will have to redo the frame so it can take the torque and idk if it more work then it worth or not waht you think
67c10 is offline
post #4 of 5 (permalink) Old 02-14-2011, 07:09 PM
04lariatfx4crewcab's Avatar
Since you have the 12v that might be worth the rework on the burban. But if you can find a 4BT that might make your life easier. I know there is a guy with an 04 F250 crew cab that has a 4BT in it and he says he pulls a 10k lb trailer with it, he isn't passing many folks but it holds its own. 4btswaps has lots of info for chevy-cummins swaps. You can always do the 4bt and if you need more motor then switch out to the 12v (a 6bt and 4bt are the same block less 2 cyl.) and worry about changing the suspension and such then. You will allways be able to sell that 4bt later.
Good luck.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #5 of 5 (permalink) Old 02-15-2011, 02:05 AM Thread Starter
im doing the 12v going 2 do a way wath gay ifs
67c10 is offline
2011 Suburban HD w/ diesel? ccampb1346 Duramax 2011+ (LML) 73 10-15-2011 06:24 AM
1995 GMC turbo diesel suburban randallhere Vehicles For Sale 2 09-28-2010 12:49 AM
1991 GMC Suburban SLE 4x4 Diesel Pipeliner_86 Vehicles For Sale 3 07-20-2010 01:30 PM
Diesel Suburban? jethrow GM Performance Forum 2 03-04-2008 06:00 PM
6.5 Suburban Diesel F.B.I 6.5L Diesel Engine 3 07-14-2007 04:24 AM
