DT466 swap in 1971 travelette - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6.9poweredscout, this thread has received 250 replies and been viewed 55205 times.
 2Likes
post #11 of 251 (permalink) Old 12-04-2012, 04:05 PM
Super Moderator
nevrenufhp's Avatar
If you have a manual with lots of gears, then go for 3.08-3.55. An auto, probably 3.31-3.55.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #12 of 251 (permalink) Old 12-04-2012, 08:00 PM Thread Starter
Bleeds IH red
6.9poweredscout's Avatar
I'm using the 5 speed thats in it. I figure I'll go 3.55 then.
1971 IH travelette crew cab long bed
Undergoing DT466 swap
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
1991 F350 crew cab dually
7.3 banks sidewinder equipped, ZF5
6.9poweredscout is offline
post #13 of 251 (permalink) Old 12-05-2012, 08:59 PM Thread Starter
Bleeds IH red
got the parts truck sunday.
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
The Following 2 Users Say Thank You to 6.9poweredscout For this addition to TDG:
nevrenufhp (12-06-2012), New 0mega (12-06-2012)
post #14 of 251 (permalink) Old 12-07-2012, 12:15 PM Thread Starter
Bleeds IH red
Where can I get a full gasket kit? I don't need the works kit with the liners and bearings. Its got low miles, just all the seals have dried up and are leaky. Also I'm only running an alternator and a ac pump, where can I get the ag pulleys I dont need 15 ribs on the pulleys. Does the power steering pump run the same pressure as a standard gm ps pump? I plan on running my hydroboost and ps through it,, just wondering if I have to regulate it down at all. Thanks!
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #15 of 251 (permalink) Old 12-07-2012, 03:32 PM Thread Starter
Bleeds IH red
Never put a picture of the travelette up. Here it is when I backed it in to start the teardown. The cab is a bare shell now and the ol 392 is out.
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
The Following User Says Thank You to 6.9poweredscout For this addition to TDG:
Golddigger (12-09-2012)
post #16 of 251 (permalink) Old 12-07-2012, 05:01 PM
Super Moderator
nevrenufhp's Avatar
A dealer or ebay for a gasket set. The ps pump will overheat and have problems necking down to 3/8. Pipewhiner sent his to PSC to get modded to work with it.
Dale
The Following User Says Thank You to nevrenufhp For this addition to TDG:
Jesse M. (01-12-2017)
post #17 of 251 (permalink) Old 12-07-2012, 05:06 PM Thread Starter
Bleeds IH red
Any specific company to look for? I've been searching google and ebay with no luck. I'll have to give psc a call.
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #18 of 251 (permalink) Old 12-09-2012, 02:29 AM Thread Starter
Bleeds IH red
started chopping up the parts rig!!!
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #19 of 251 (permalink) Old 12-09-2012, 04:19 PM
Golddigger's Avatar
Looks Like a fun project.
2002 F-350 CC, Shortbed, 4X4, rebuilt 7.3, EBV brake, 4" dual exhaust, B&D compressor wheel, head studs, Gear head performance 6 pos, Banks Big Head, built 4R100 w/triple disc torque conv, Shift kit, 204K, B&W Hitch and 5th wheel companion, Superlift Air Bags, 35 x 12.50 x 17 BFG KM2:
The veiws expressed are purely opinion. I in no way take responsibility for any actions or damage as a result of trying this at home.
Local 3 OPERATORS UNION
2005 Chevy 7500 C-7/Allison, Service box off of my '93 Int
Golddigger is offline
post #20 of 251 (permalink) Old 12-10-2012, 03:55 AM Thread Starter
Bleeds IH red
well i chopped up the cab and chassis today. :
my friend taking it for a drive....
any info on this trans.... first gear ratio? od..?
that's it for today! on:
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
DT360 swap to a DT466 Kman Medium and Heavy Duty 2 07-04-2011 08:30 PM
72 F350 crew, DT466 swap on Craigslist. nevrenufhp Diesel Conversion 11 01-29-2011 03:43 AM
DT466 Trans Swap ???'s 99busa Medium and Heavy Duty 1 06-26-2009 02:49 PM
DT360 Swap To DT466 Iceman Medium and Heavy Duty 6 05-02-2008 09:20 PM
65 travelette with a 6.9/7.3 IDI Link37 Diesel Conversion 5 03-29-2008 02:35 AM
