International MXT.. Engine and trans swap - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ScrapGy, this thread has received 31 replies and been viewed 22993 times.
post #11 of 32 (permalink) Old 08-01-2013, 02:13 PM
Super Moderator
nevrenufhp's Avatar
Exhaust temp, and possibly drive pressure.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #12 of 32 (permalink) Old 08-01-2013, 03:07 PM Thread Starter
International MXT
Thanks! Can't say I even know what drive pressure is!
ScrapGy is offline
post #13 of 32 (permalink) Old 08-01-2013, 03:37 PM
Super Moderator
nevrenufhp's Avatar
Drive pressure is tapped in to the exhaust manifold. Basically another booost gauge, but reads the pressure it takes to spin all them turbos. More of a tuning tool.
Dale
post #14 of 32 (permalink) Old 08-01-2013, 05:42 PM Thread Starter
International MXT
Should I get a 60 or 100psi boost gauge and how big for the drive pressure? Thanks Dale!
ScrapGy is offline
post #15 of 32 (permalink) Old 08-01-2013, 05:45 PM
Super Moderator
nevrenufhp's Avatar
Get the 100 pounds, since you may sneak past 60 pounds.
Dale
post #16 of 32 (permalink) Old 08-01-2013, 06:05 PM Thread Starter
International MXT
100 for both it is. Autometer has a select number of boost gauges for 100 psi but I may put them somewhere other than my dash
ScrapGy is offline
post #17 of 32 (permalink) Old 08-14-2013, 06:19 PM Thread Starter
International MXT
My transmission came in Last week, went with a RoadRanger RTX 10 speed.
I have a few questions on my engine... For the rebuild, I am trying to get the HT rebuild kit as I am going to turn the engine up to about 500 HP, International is having some issues w no VIN from a truck to know exactly what I need. I have a 95 year model engine all Mchanical. Anyone have any suggestions? Thanks
ScrapGy is offline
post #18 of 32 (permalink) Old 08-15-2013, 10:24 PM
Super Moderator
nevrenufhp's Avatar
surprising there's no advice/comments. I came up with a 13mm pump and injectors, stock turbo on top of an HT3B/26, and a HT530 inframe kit with crank so it gets 2 pc steel pistons to survive a few degrees of EGT.
Dale
The Following User Says Thank You to nevrenufhp For this addition to TDG:
ScrapGy (08-16-2013)
post #19 of 32 (permalink) Old 08-16-2013, 12:03 AM Thread Starter
International MXT
Thanks for the help, I am looking into HT530 inframe Kit on that list you sent over as well as fuel pump and injectors. How much boost should I run with the 530 kit?
ScrapGy is offline
post #20 of 32 (permalink) Old 08-16-2013, 12:13 AM
Super Moderator
nevrenufhp's Avatar
I say it will be around 45 pounds.
Countdown to SEMA!
Dale
International MXT "Engine Light" Idleup 2003-2007 6.0L Power Stroke 11 07-15-2013 04:28 AM
'73 International swap to 6.9 ihv800 7.3L and 6.9 IDI (Pre 1994) 24 07-18-2007 03:15 AM
blue international cps swap from dt466e sidssm 1994-2003 7.3L Power Stroke 19 04-19-2007 01:09 AM
MXT Engine ?'s RWS31 Medium and Heavy Duty 66 04-16-2007 04:20 PM
Engine and trans swap Ggg 7.3L and 6.9 IDI (Pre 1994) 1 01-11-2006 08:33 PM
