International MXT.. Engine and trans swap - Page 3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ScrapGy, this thread has received 30 replies and been viewed 21887 times.
post #21 of 31 (permalink) Old 08-15-2013, 11:15 PM Thread Starter
International MXT
Originally Posted by nevrenufhp View Post
I say it will be around 45 pounds.
Countdown to SEMA!
Dont remind me hahaha. So a bit less with the 530 than the 466 or is that what we had talked about as well?
ScrapGy is offline
post #22 of 31 (permalink) Old 08-15-2013, 11:40 PM
Super Moderator
nevrenufhp's Avatar
The same pressure either way, within a couple pounds of each other.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #23 of 31 (permalink) Old 08-14-2014, 11:55 PM
Super Moderator
nevrenufhp's Avatar
I got some updates. The engine is in, and it fired up last week. He had to do a suspension lift, so it got converted to coilovers on all 4. Ironically, one of the suspension gurus that works on Grave Digger helped with some of the 4 link. Most of the lack of updates were because of waiting on Industrial Injection for the pump work.
http://instagram.com/p/qKo94eDlen/
http://instagram.com/p/qKaCf-jlR5/
http://instagram.com/p/ohG6_6DlWx/
http://instagram.com/p/n68ju7DleG/
http://instagram.com/p/rGYqXADlaU/
http://instagram.com/p/q7flxmjlVV/
Dale
The Following User Says Thank You to nevrenufhp For this addition to TDG:
ScrapGy (01-08-2015)
post #24 of 31 (permalink) Old 08-15-2014, 05:43 PM
Pardue the Traveler
New 0mega's Avatar
you could carry a small car underneath that thing
Singles Club member #250
New 0mega is offline
post #25 of 31 (permalink) Old 12-30-2014, 12:58 PM
The swap looks great. That thing will be a beast with the coil over lift. It is already a really big truck to drive around stock. A lot of the roads around my house are too small for it to even fit within the lines. Were you able to do anything about the turning radius when you swapped your suspension?
mattgarrett is offline
post #26 of 31 (permalink) Old 01-08-2015, 03:43 PM Thread Starter
International MXT
Getting closer
So I had the MXT done and running.... (I moved it a few feet) The engine and trans fell into place but limited my travel so I decided to do some suspension work... Its now 4 linked dual coil over on each front corner and bagged rear with dual remote resi shocks... I was scared of what would happen with the transfer case as that became my weak link, the more and more research I did on New Process Gear the more and more concerned I became. I went with an SCS gearbox and finished the truck up.. No perm gauges or anything just enough to make sure everything was correct. Along the way I came across some axles called Axletech 4000 Planetary Steer axles... Those are not going in front and rear...
It has come a long way and will be driving once again really soon.
ID:	37657   Click image for larger version
ID:	37665   Click image for larger version
ID:	37673   Click image for larger version
ID:	37681   Click image for larger version
ScrapGy is offline
post #27 of 31 (permalink) Old 01-08-2015, 03:53 PM Thread Starter
International MXT
Thanks!!
I tried sending some pictures to your phone but they won't seem to go through... Truck is/was done!!
here is what is going on now if you had not seen.
ID:	37697   Click image for larger version
ID:	37705   Click image for larger version
ID:	37713   Click image for larger version
ID:	37721   Click image for larger version
ScrapGy is offline
The Following User Says Thank You to ScrapGy For this addition to TDG:
nevrenufhp (01-08-2015)
post #28 of 31 (permalink) Old 01-08-2015, 03:55 PM Thread Starter
International MXT
The turning radius is much better than my F250... but yes, I now have 4 wheel steer with axles that can turn 45 Degrees.
ScrapGy is offline
post #29 of 31 (permalink) Old 01-09-2015, 12:53 AM
Super Moderator
nevrenufhp's Avatar
Originally Posted by ScrapGy View Post
Thanks!!
I didnt see any of those pix before. How is the exhaust routed now? I bet it sounds amazing!
Dale
post #30 of 31 (permalink) Old 01-13-2015, 03:56 PM Thread Starter
International MXT
Just a strait pipe down at the moment, I do not have all of the 5' SS pipe back from the benders yet
ScrapGy is offline
International MXT "Engine Light" Idleup 2003-2007 6.0L Power Stroke 11 07-15-2013 03:28 AM
'73 International swap to 6.9 ihv800 7.3L and 6.9 IDI (Pre 1994) 24 07-18-2007 02:15 AM
blue international cps swap from dt466e sidssm 1994-2003 7.3L Power Stroke 19 04-19-2007 12:09 AM
MXT Engine ?'s RWS31 Medium and Heavy Duty 66 04-16-2007 03:20 PM
Engine and trans swap Ggg 7.3L and 6.9 IDI (Pre 1994) 1 01-11-2006 07:33 PM
