Dt466 in 1995 F-350 - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jesse M., this thread has received 36 replies and been viewed 8036 times.
 4Likes
post #11 of 37 (permalink) Old 01-11-2017, 01:54 AM
Bleeds IH red
6.9poweredscout's Avatar
Cool. What cfm is that 3 blade fan? I'm running a single Volvo car fan in my truck. No issues at all.
Sent from my SM-G920V using Tapatalk
1971 IH travelette crew cab long bed
Undergoing DT466 swap
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
1991 F350 crew cab dually
7.3 banks sidewinder equipped, ZF5
6.9poweredscout is offline
post #12 of 37 (permalink) Old 01-11-2017, 01:57 AM Thread Starter
Jesse M.'s Avatar
I think it's rated at 7400 or 7600. The fan motor fit like it was made to go between the engine pulleys, just enough space to change belts.
Sent from my iPhone using Tapatalk
Jesse M. is offline
post #13 of 37 (permalink) Old 01-11-2017, 01:58 AM
Bleeds IH red
Sweet. Anything done to the engine?
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #14 of 37 (permalink) Old 01-11-2017, 01:58 AM Thread Starter
Jesse M.'s Avatar
I think the DT's run pretty cool unless you really push them. I could probably get away with less fan, but I like to over build when I can
Jesse M. is offline
post #15 of 37 (permalink) Old 01-11-2017, 01:59 AM
Bleeds IH red
I work the crap out of mine with the ac going and never an issue.
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #16 of 37 (permalink) Old 01-11-2017, 02:00 AM
Bleeds IH red
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #17 of 37 (permalink) Old 01-11-2017, 02:00 AM Thread Starter
Jesse M.'s Avatar
I have the "A" pump turned up as high as the shop would take it, and I got a GT37 turbo off a 466E. I'm going to see how it drives before going crazy adding power.
Jesse M. is offline
post #18 of 37 (permalink) Old 01-11-2017, 02:05 AM
Bleeds IH red
Yeah on my 360 it's a maxed A pump at 24 degrees timing with stock injectors and a S360 turbo. The 466 is a modified mw pump at 27 degrees timing with 4x.018 injectors with a S366 turbo.
1980 Scout Terra
6.9/T19/NP205
D60s on 39.5s
post #19 of 37 (permalink) Old 01-11-2017, 02:05 AM Thread Starter
Jesse M.'s Avatar
What is your RPM at 70mph? How does it do on fuel? I'm supposed to go pick up an Allison transmission Saturday, but it's non OD. My math puts it right around 2100 rpm at 70
Jesse M. is offline
post #20 of 37 (permalink) Old 01-11-2017, 02:07 AM Thread Starter
Jesse M.'s Avatar
I bumped my timing from 14* to 19*, how did you come to 24?
Jesse M. is offline
1995 international dt466 ac questions Blackdog3 Medium and Heavy Duty 5 05-25-2015 05:05 PM
Pa 1995 International dt466 Blackdog3 Introductions 2 03-14-2015 06:55 PM
1995 DT466 Farmall91 Medium and Heavy Duty 9 12-05-2010 05:33 PM
1995 International 4700 w/ DT466, just a question. Robert1320 Medium and Heavy Duty 82 01-07-2008 02:22 PM
1995 IH donor truck, DT466 nevrenufhp Diesel Conversion 6 03-28-2007 11:46 PM
