Help me out - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Matt05, this thread has received 19 replies and been viewed 1456 times.
post #1 of 20 (permalink) Old 01-02-2009, 06:24 AM Thread Starter
Ultra Member
Matt05's Avatar
Help me out
I may have found an incredible deal on a Cummins to throw in my old 96, but it is out of a 93. What is the difference between a 93 and a 94? Just the pump?
2008 Ford F-350 XLT Regular Cab: 35" Toyo MTs, 2.5 Icon Leveling Kit, Keystone Hood, 4" Magnaflow, 6" tip, dpf/doc delete, S&B Intake, Spartan Tuned, Autometer Gauges
Waiting to install: Icon TEI Spacer, Icon 4-Link, OUO Traction Blocks, 35" Toyo MTs on 20x10 BMF Novakanes, Spearco Intercooler, Polished IC Pipe, EGR Delete, Polished Intake Elbow
Matt05 is offline
post #2 of 20 (permalink) Old 01-02-2009, 01:04 PM
the biggest difference is the 93 has a ve rotarty pump were a 94 has a the p7100 inline pump. given the choice you would want the p 7100pump. The ve pump is a very good pump though.
2005 3.9 Cummins 4BTAA 94 dodge 1500 2wd A518 trans 27 mpg around town
http://www.cumminsforum.com/forum/cu...ics-truck.html
Friends 95 dodge 2500 #6 fuel plate and 35lbs of boost.
JakeDiesel is offline
post #3 of 20 (permalink) Old 01-02-2009, 03:31 PM Thread Starter
Ultra Member
Matt05's Avatar
I was planning on just putting a p7100 pump on the 93. What other differences is there?
Matt05 is offline
post #4 of 20 (permalink) Old 01-02-2009, 06:44 PM
GOS
GOS's Avatar
If you want a real good deal, we've got a 97 P7100 12V with 90,000 original miles along with absolutely everything you need to put in into a 96 Ford, shoot me a PM if interested.
Contact 1-800-620-4467
Fax 1-406-222-4926
[email protected]
GOS is offline
post #5 of 20 (permalink) Old 01-02-2009, 10:42 PM
********* and Mafia #90
Bcarriveau's Avatar
GOS, werent you getting me a price a wile back on doing a CR swap im my truck : Or even supplying me with whats needed?!(dodge auto behind it)
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 20 (permalink) Old 01-02-2009, 10:46 PM Thread Starter
Ultra Member
Matt05's Avatar
You wanna give up on your 6.0 already?
Matt05 is offline
post #7 of 20 (permalink) Old 01-02-2009, 11:01 PM
Bcarriveau's Avatar
Iv had it almost 3 years now. If always wanted a ford/cummins. I can say its been almost a year on new heads, turbo, ect and the truck has not puked once since the arps went in with the 2nd set of hgs. I run a 150HP tune all day every day, unless towing big. My list is pretty big from this year of parts that were replaced.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #8 of 20 (permalink) Old 01-02-2009, 11:15 PM Thread Starter
Ultra Member
Matt05's Avatar
I'd really like to have a cummins in my old 96, but I want to slowly put it together. I don't need it running immediately, just a nice little project, so I'm looking for a cheap 12valver. Conversions are the chit
Matt05 is offline
post #9 of 20 (permalink) Old 01-02-2009, 11:16 PM
Diesel Pro
Macktruckdriver's Avatar
The 93 motor is not the same. Its not worth putting in your truck. I dont think you can even P-pump them. You might be able to but the motor is not the same.
Macktruckdriver is offline
post #10 of 20 (permalink) Old 01-03-2009, 04:21 AM
The 93 motor can be p pumped. At worst you just have to change the front gear trans they use the same injectors on the same side of the head, it should be that big of a problem to p pump.
