Putting a Perkins into a 86 Blazer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acudanut, this thread has received 3 replies and been viewed 501 times.
post #1 of 4 (permalink) Old 01-31-2019, 03:08 PM Thread Starter
Does anyone know what will I need ? The K-10 Blazer is a Military M-1009. I it has a turbo 400 automatic transmission.
acudanut is offline
post #2 of 4 (permalink) Old 01-31-2019, 05:43 PM
Jesse M.'s Avatar
Interesting project, it will be really cool if you get it done.
You will probably need a custom bell housing, to keep the th400, I don’t think they were ever put behind a Perkins. Otherwise, to keep 4wd, transmission and t-case options will be limited by the Blazer’s short wheel base. Adapting the th400 to the Perkins OR adapting a t-case to mate directly to a transmission with an SAE bell housing will be your best options, and probably the hardest part of the project. I’m not aware of any “off the shelf” combinations for either route, and running a divorced case in a blazer would be tricky, especially if the engine swap requires any suspension lift for clearance, the rear drive shaft angle would be super steep. If you can give up 4wd, there are loads of transmission options that would probably bolt up to the Perkins with easily sourced parts. A manual transmission like a Spicer or Eaton would be the easiest in my opinion. After that, fabricating engine mounts, and depending which model Perkins, fitting it under the hood, will be your biggest hurdles.
I don’t know your skills or budget, but it will certainly require a fair amount of problem solving, fabrication, and most likely some custom machined parts.
Jesse
Sent from my iPhone using Tapatalk
Jesse M. is offline
post #3 of 4 (permalink) Old 01-31-2019, 05:51 PM
Jesse M.'s Avatar
An Allison 1000 is the only transmission I can think of that is available with an SAE bell housing, AND an mated T-case.
Jesse M. is offline
post #4 of 4 (permalink) Old 11-03-2019, 12:00 PM
Maksimka's Avatar
Maksimka is offline
12v Cummins Conversion into '86 K30 Chevy meenag01 Introductions 1 09-10-2012 12:00 AM
v8 perkins into a 1 1/2 truck 1964reo Diesel Conversion 2 03-10-2010 02:44 AM
Cant talk dealer into putting ARPs in. Bendog 2003-2007 6.0L Power Stroke 24 02-06-2008 02:23 PM
86 blazer axle question Chris88 General Gas Vehicle 0 04-17-2007 05:42 PM
Looking for a 85-86 Blazer with a 6.2 or 6.5 CSIPSD 6.5L Diesel Engine 8 07-14-2006 04:52 PM
