4bt in a jeep? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Trev1981, this thread has received 20 replies and been viewed 4086 times.
post #1 of 21 (permalink) Old 12-29-2006, 05:09 AM Thread Starter
4bt in a jeep?
i was thinking of putting a 4bt in my 88 yj wramgler, do you think a built 700r4 would be a good choice?
or i might just use a 6.5 turbo diesel insted
Trev1981 is offline
post #2 of 21 (permalink) Old 12-29-2006, 07:59 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
I think a good pro built 700 r-4 might handle a stock 4bt and maybe even a turned up one. Just as long as the transmission isn't completely stock, then I don't think it would hold up too long. A lot of them didn't live long behind 305's, but this is just my opinion. You would be better off with a 4L60E, but that would require a comp u shift module and I know they aren't cheap. so maybe spending a little on the 700 R-4 might be the way to go for you.
Putco light bar
Dieselwrencher is offline
post #3 of 21 (permalink) Old 12-29-2006, 01:13 PM
01duramax6spd's Avatar
I've seen/heard of numerous Jeeps with 4bt's. I'd personally run a NV4500
5spd or a TH400. I hate auto's so the NV would be my pick.
01duramax6spd is offline
post #4 of 21 (permalink) Old 12-29-2006, 03:00 PM
Super Moderator
John_G's Avatar
I would NOT use a 6.5L, compared to the "B" cummins, they are junk.
The later 700R4s are decent transmissions, and often used in panel trucks, so you may be able to find a complete engine/trans combo. I would shy away from the early R4s as their durability is poor at best - unless reworked to later standards.
The "4B" in a Jeep should return excellant fuel economy and great pulling power, that would be a great swap I think.
I vote for LIBERTY!
John_G is offline
post #5 of 21 (permalink) Old 12-29-2006, 10:04 PM
Send a message via AIM to 250stroke Send a message via MSN to 250stroke Send a message via Yahoo to 250stroke
http://www.screaminseeman.com/cummins.htm
They make motor mounts, Ive been considering it myself but dont have enough money for all my projects as it is.
2004 F-250 Crew-cab XL 2wd 83000 miles . 4" straight pipe.
10/97 F-250, 180k on the clock, 4.10 gears, Autometer gauges,DIY intake, 3.5" down pipe to 4" straight , ATS 6 position chip, 37" BFG Baja T/A's and 24 bolt Hummer H1 wheels. 1 ton axles and custom suspension.
250stroke is offline
post #6 of 21 (permalink) Old 12-29-2006, 11:38 PM
Super Moderator
nevrenufhp's Avatar
Or, another place that just deals with a diesel swap:
www.jeep2diesel.org
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #7 of 21 (permalink) Old 12-30-2006, 01:58 AM
Send a message via Yahoo to 4x4ford
i know a friend of mine that has a diesel out of a chevette in an old military jeep but i dont remember what all they had to change to get it all to work
4x4ford is offline
post #8 of 21 (permalink) Old 12-30-2006, 02:35 AM
2-Stroke God
DieselPower's Avatar
Here you go, A great 700r4 for cheap.
http://cgi.ebay.com/ebaymotors/700R4...mZ330067589853
Mad dog is a great place to work with. Get a 4bt back plate from a step-van, and this tranny will bolt right on. They do make a TC that fits between, but they are a little hard to find. The small bolt circle chev TC is just about 1/2 hole off on the flex plate. So what I do is mount the flex plate in my lathe and weld a washer to it with a little jig that holds it in place, and then re-bore the hole. i have had no trouble with this method so far. If you want the part number for the TC that does fit, I'll give it to you.
DieselPower is offline
post #9 of 21 (permalink) Old 12-30-2006, 02:50 AM
2-Stroke God
http://www.advanceadapters.com/ also has Tcase adapters for just about any tranny you would want to use.
post #10 of 21 (permalink) Old 12-30-2006, 04:14 AM
That 4bt-GM tranny isn't cheap. Last one I saw went for $650.
