Just say no to Heui!
LinkBack | Thread Tools | Display Modes |
'05/'06 Cummins from a Freightliner for engine swap?
I am posting this here because I have yet to receive any help/ideas from the other places I have it posted. I bought a box van that has a Freightliner chassie under it. I plan on using the engine and transmission (Allison 1000) for repowering a truck. I plan on putting a set of twins on it for towing and maybe even duel cp3's. I would almost bet money that the ecm that is currently on this truck will not work with Dodge programmers. Can anyone confirm this? It doesn't have an OBDII port but a round connector instead. Can I replace this connector with an OBDII connector? Can I have the ecm reflashed with Dodge program or do I have to buy a Dodge ecm? Also does the Allison tcm talk to the engine ecm? Can I still use the stock Allison tcm or do i need to get the stand alone controler? Is there other things I need to look into when swapping over to dodge electronics?
My trucks:
2007.5 Dodge Ram 2500 Quad-cab, Long Horn Edition, 6.7 Cummins, 6spd auto, 4x4, 4" lift and 33's. No Dpf, not Egr, dual exhaust, and a Xrt with the 175hp tune.
2000 Ford F-550 Crew-cab, XLT, 7.3 Powerstroke, 4spd auto, 4x4. Gearing up for a '08 6.7 Cummins common rail & Allison 1000 swap.
1997 Ford F-250HD Extended-cab, XLT, 7.3 Powerstroke, 4spd auto, 4x4. P-pump Powerstroke sled puller project. (In progress)
Sponsored Links | |||
Administrator
I don't know all the answers to your questions, but SonCoast does make, or has a stand aloe for the Allison, to use behind a Cummins.
I am sure the PCM is not the same as a Dodge Truck.
If its an 06 motor you may have problems with the electronics. I know on the dodges they have a coded key and causes problems with wireing it up infact I was told by both Autoworld and Beans to stay away from the 2006 motors. Maybe the frieghtliner motors are different
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Twin turbos
TDG Mafia #76
Call Scott at Destroked. They've got a complete stand alone controller for the Allison and all the other parts you'd need for a conversion. Good people!!!
Jarrett
04.5 qcsb commonrail
Smarty TnT
Smarty TnT
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
'05/'06 Cummins from freightliner? | Moulder | 5.9L Cummins (2003-2007.5) | 0 | 01-29-2009 07:13 PM |
Engine Swap | michael8840 | 1994-2003 7.3L Power Stroke | 2 | 03-14-2008 02:37 AM |
Engine Swap | 1964reo | 5.9L Cummins (Pre 1994) | 10 | 01-08-2008 04:53 AM |
6.9 to 7.3 engine swap | alr | 7.3L and 6.9 IDI (Pre 1994) | 0 | 11-14-2007 04:45 PM |
99 to 97 engine swap | moboy | 1994-2003 7.3L Power Stroke | 3 | 08-23-2007 05:04 PM |
Posting Rules | |
