Anyone out there swapped a 12v into a 48-50 ford pickup? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JD99PSD, this thread has received 2 replies and been viewed 1214 times.
post #1 of 3 (permalink) Old 05-18-2009, 07:26 PM Thread Starter
PSD addict!
Hi,
I'm thinking a 1st gen 12v with a Getrag 360 5 speed 2wd into a '49 ford F-3 dually. Found the truck local and cheap, and have always had visions of a cummins powered early Ford pickup. Anyone done it, havea link to any pics of one?? Looking for info or advice.
Thanks,
Jason
'08 F350 Crew Cab 2wd Dually, Custom two toned black over silver, lowered 2"/4" 22" alcoa's w/304/40/22s, SCT Livewire w/RCD tune, flowpro dpf delete.
1984 Volvo 760 GLE, D24T I-6 12v turbo diesel, ARP head studs, MLS head gasket, ported/polished head with 3 angle valve job, turned up pump, front mount IC, custom built T3/T4, monster dura-lite filter, 3" turbo back, WC T-5 swapped, clutchnet 6 puck disc.
Look for it in Diesel Power soon!
JD99PSD is offline
post #2 of 3 (permalink) Old 05-19-2009, 12:07 AM
Super Moderator
nevrenufhp's Avatar
I saw over on 4BTswaps that someone is putting in a Cummins A in an old timer. He said it's the same size as a stock inline 6 of the day. Having owned a 48 F1 before, I'd be double checking length & height. A few years back I also saw a Triton V10 in a 49 F1, so it's possible. I really dig them big fenders!
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #3 of 3 (permalink) Old 05-19-2009, 01:44 AM Thread Starter
PSD addict!
Sounds good, the one I'm looking at has a straight six as well. From some of the reading I have done, it sounds like the cummins isn't any heavier then the flathead was. Apparently they are a pretty hefty chunk of steel.
Jason
JD99PSD is offline
Best Year for Ford Diesel Pickup? ssorange General Ford Truck and Excursion 39 06-10-2009 04:22 AM
1988 Chevy C30 With a 5.9L CTD swapped in it 6Lcummins Diesel Conversion 22 01-10-2008 09:26 PM
Swapped gears but not a big difference? skav 1994-2003 7.3L Power Stroke 6 09-18-2007 02:17 PM
Has anyone swapped out a stick for an auto? skav 1994-2003 7.3L Power Stroke 7 07-05-2007 03:09 AM
My pickup got hit... John Deere The Parking Lot 21 03-15-2006 03:27 AM
