DT360 swap in progress - Page 3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pipewhiner, this thread has received 108 replies and been viewed 110840 times.
 2Likes
post #21 of 109 (permalink) Old 09-20-2009, 12:45 AM
Super Moderator
nevrenufhp's Avatar
Originally Posted by pipewhiner View Post
Motor is in the truck, motor mounts are done....
You cant tease us like this!
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #22 of 109 (permalink) Old 09-20-2009, 02:03 AM
What did the engine and plate set you back?
dragogt is offline
post #23 of 109 (permalink) Old 09-20-2009, 01:42 PM Thread Starter
pipewhiner's Avatar
Engine was cheap.. reman with only 30k on it for $1500. Adapter plate and flex plate, still haven't gotten a bill, should be inline with the cummins adapters. I hope to get this all done cheaper than an average 5.9 cummins conversion or around the same cost so that people have a different choice....
1999.5 CC, 4x4, F-350 dually. Brugundy/Black Future Tuning by Bosch!!! 416/860
http://community.webshots.com/user/pipewhiner
pipewhiner is offline
post #24 of 109 (permalink) Old 09-20-2009, 02:56 PM
Sweet sounds good; 30k man that engines not even broke in yet, 'aught to run forever.
dragogt is offline
post #25 of 109 (permalink) Old 09-21-2009, 10:01 PM
TDG Mafia Member #56
Dieselwrencher's Avatar
I wonder if the your guy could build one for a DT408?
Putco light bar
Dieselwrencher is offline
post #26 of 109 (permalink) Old 09-22-2009, 03:56 PM Thread Starter
pipewhiner's Avatar
An adpapter plate? sure anything is possible.... I belive the 408 is bigger in size maybe built on the 466 block?
post #27 of 109 (permalink) Old 09-22-2009, 10:58 PM
I think you're right. I think it is near the 466 block.
Putco light bar
post #28 of 109 (permalink) Old 09-26-2009, 09:20 PM
********* and Mafia #90
Bcarriveau's Avatar
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #29 of 109 (permalink) Old 09-28-2009, 12:42 PM Thread Starter
pipewhiner's Avatar
I'll get some pics, when it's running at the end of the week lol
The Following User Says Thank You to pipewhiner For this addition to TDG:
Binderpower (09-28-2009)
post #30 of 109 (permalink) Old 10-04-2009, 02:21 AM
Super Moderator
John_G's Avatar
The DT408 IS a DT466 (NGD varient) with a shorter stroke but sharing the same bore, head and block. Only made for 2.5 years (1994-1996.5).
I vote for LIBERTY!
John_G is offline
The Following 3 Users Say Thank You to John_G For this addition to TDG:
Dieselwrencher (10-07-2009), dragogt (10-06-2009), nevrenufhp (10-04-2009)
DT360 Swap To DT466 Iceman Medium and Heavy Duty 6 05-02-2008 09:20 PM
Dt360 manual to automatic swap? drypondscout Medium and Heavy Duty 7 11-26-2007 04:14 PM
Farming Progress thejdman04 The Parking Lot 10 11-10-2007 02:11 AM
1989 1754 DT360 engine swap Iceman Medium and Heavy Duty 2 09-02-2007 02:49 PM
Making progress D2HP General Ford Truck and Excursion 1 09-30-2006 12:06 AM
