DT360 swap in progress - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pipewhiner, this thread has received 108 replies and been viewed 110973 times.
 2Likes
post #1 of 109 (permalink) Old 06-22-2009, 03:01 PM Thread Starter
pipewhiner's Avatar
I finally made it to Ohio to get my inline-pumped DT360 for the new swap. It was quite an eventful trip but ended well. I dropped the motor off to Carsons on Thursday morning. He will be doing the adaptor plate and motor mounts for me as well as the work on the Bosch pump, probably more as the project progresses.
Mods to be done:
either modify the A pump or go to the P-pump and associated mods
Pushrods and valve springs to prevent valve float over 4200 rpms
S300 or similar turbo
and we're off to the races. I only desire mid 500's on this build for now but according ot hypermax 3000 HP is capable on this motor.
The cummins swap is getting popular so I wanted something different. The DT360 is dimensionally similar to the 5.9 same displacement, but much stronger in almost every department. I will try to keep this updated as the project progresses.
niteowl likes this.
1999.5 CC, 4x4, F-350 dually. Brugundy/Black Future Tuning by Bosch!!! 416/860
http://community.webshots.com/user/pipewhiner
pipewhiner is offline
post #2 of 109 (permalink) Old 06-22-2009, 10:44 PM
UpstateDieselGuy's Avatar
Good Luck with the swap. I bet it will be awesome. Chris
niteowl likes this.
SOLD
UpstateDieselGuy is offline
post #3 of 109 (permalink) Old 06-23-2009, 12:59 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
That will be awesome. I just found a DT408 in a school bus i'm trying to deal on. I am in the same boat as you. I want something different. We have plenty of ford cummins's here.
Putco light bar
Dieselwrencher is offline
post #4 of 109 (permalink) Old 06-23-2009, 01:37 AM
Super Moderator
nevrenufhp's Avatar
That's a beautiful thing!
Your pump can push way more fuel than an S300 can feed. Personally, I would only switch to a P-pump if the price was right. I had a long talk with my local injection shop about the A, MW, and P-pumps.
I tried to do the DT466 swap, but life happens. I'll keep my hopes up for doing it some day.
You'd be surprised what these engines can do without even opening em up!
Oh.....
We need pix!!!!
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #5 of 109 (permalink) Old 06-23-2009, 01:55 AM
Still Diggin
KWT800's Avatar
Sounds like a sweet project. Ill be interested to see how this turns out.
KWT800 is offline
post #6 of 109 (permalink) Old 06-23-2009, 11:34 PM Thread Starter
pipewhiner's Avatar
I only want mid 500's.... anything more for a daily driver tow machine would melt down the drivetrain behind it... u-joints, rear ends, etc.... I dont want it laggy either, so maybe a small s400 is in order. I also think the A-pump will put out all the fuel I need too for now. This should be a fairly reasonable swap especially after I hoe that row for all the others with the adaptor plate and flywheel for the 4r100. Pics will be up once there is something interesting to post.
post #7 of 109 (permalink) Old 06-24-2009, 01:08 AM
fuzzys69's Avatar
im ready
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #8 of 109 (permalink) Old 07-07-2009, 07:47 PM Thread Starter
pipewhiner's Avatar
I've posted all my PSD performance stuff in the for sale section. Have at it boys...
The motor fits in the truck and its at the CNC guy now for the adaptor plate. Progress is being made.
The Following User Says Thank You to pipewhiner For this addition to TDG:
nevrenufhp (07-07-2009)
post #9 of 109 (permalink) Old 07-07-2009, 11:27 PM
Super Moderator
nevrenufhp's Avatar
No sample pictures of it sitting in there? A teaser shot?
Dale
post #10 of 109 (permalink) Old 07-08-2009, 04:31 PM Thread Starter
pipewhiner's Avatar
Adaptor plate should be made sometime early next week. Then it's all downhill from there. As far as the motor in a truck, it's in a mock up truck right now figuring out the motor mounts. There is no mid-mount option on this motor so new crossmembers etc are in order.
DT360 Swap To DT466 Iceman Medium and Heavy Duty 6 05-02-2008 09:20 PM
Dt360 manual to automatic swap? drypondscout Medium and Heavy Duty 7 11-26-2007 04:14 PM
Farming Progress thejdman04 The Parking Lot 10 11-10-2007 02:11 AM
1989 1754 DT360 engine swap Iceman Medium and Heavy Duty 2 09-02-2007 02:49 PM
Making progress D2HP General Ford Truck and Excursion 1 09-30-2006 12:06 AM
