Cummins to Spicer transmission - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Machinos, this thread has received 12 replies and been viewed 24300 times.
post #1 of 13 (permalink) Old 02-23-2010, 03:08 AM Thread Starter
Howdy all - this isn't EXACTLY a diesel conversion, but it seemed like the best place to ask this question.
I've got a '90 Dodge 1 ton with the 5.9 Cummins and stock 727 auto. I want to tow fairly heavy loads long distances, so the auto needs to go. After a lot of research I decided the best option for the price would be a medium-duty 5 speed, Eaton or Spicer being the two real options.
Eatons seem to come attached to Cummins engines a lot more often, but Spicers are WAY more common, and then I found one for $50 so naturally I bought it.
The main problem is that practically every Spicer, this one included, came behind an International engine and has an SAE2 clutch housing. SAE3 flywheel housings for the 5.9 Cummins are the most common, and in fact I have one attached to a loose 5.9 I've got.
THE QUESTION: What's the best way to attach a Spicer 5-speed to my 5.9 Cummins? The main thing is having matching SAE flywheel and clutch housings, but stuff like which clutch, input bearing, spacers, etc. are things I'm unfamiliar with.
Thanks!
Machinos is offline
post #2 of 13 (permalink) Old 02-26-2010, 04:22 PM
first off what spicer did you get. you might be better off selling the spicer, make a little profit, and get yourself a fuller set up. fuller is a better unit on average anyway.. chk your pm's
navistar45 is offline
post #3 of 13 (permalink) Old 03-01-2010, 07:31 AM Thread Starter
Thanks for the info! Here's the link for anyone else - http://www.sanco-bg.com/nv5600_conversion_FO8406.htm
Pretty similar swap obviously, but would the parts be the same for a Spicer? The one I got is an older 6352 but they all seem pretty similar. I can't find specs for that exact model but I'm guessing it's the same as the ones in the buses at work, rated at 60k GVW.
I've been looking for Eatons too, and they did seem like a better way to go, but couldn't find one for a good price (don't know how he found a 6 speed for $150). I've run the gear ratios through calculators and I think I should be fine with this trans since the truck came with a 3.07 rear. Might need a higher RPM governor spring to really run it well though, but we'll see.
Machinos is offline
post #4 of 13 (permalink) Old 04-25-2010, 12:08 AM
SAE Bell housings and Flywheels? Confusion.
I've been digging around trying to find our about these. If a Cummins has an SAE #2 bell housing and my Deutz is drilled for SAE #2, then I can use the Cummins bell housing as long as the starter will mesh with the ring gear - right?
DieselSchlepper is offline
post #5 of 13 (permalink) Old 04-26-2010, 09:17 AM
Euro Sparky/ Wrencher
french277's Avatar
Peut-être ou peut-être pas tout il selon à quelle distance le mécanisme d'anneau est s'aligne avec le mécanisme de démarreur.
Le Deutz et Cummins le modèle de boulon au bloc tous les deux ne sont pas les mêmes du tout, mais pour le volant hébergeant le modèle ouais tous les deux sont les mêmes.
Maybe or maybe not all it depending on how far the ring gear is line up with the starter gear.
The Deutz and Cummins bolt pattern to the block both are not the same at all but for the flywheel housing pattern yeah both are the same.
Merci,Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
french277 is offline
post #6 of 13 (permalink) Old 05-12-2010, 05:10 PM
hayjayhorses's Avatar
I am putting a Road Ranger RTO9513 behind a cummins 5.9, The Flywheel you need is 14” FLYWHEEL, 14" CLUTCH, CASTING # 3908574, BEARING # AB190 (6206) 1 3/4",RING GEAR # AF3903309. I found them on ebay for $195 (item # 230335722221) Any truck junk yard should have a #2 SAE flywheel housing. I was in Dallas at a big truck junk yard they must of had 30 cummins 5.9 with #2 housing on them. If you go buy a Truck Trader at the gas station you will see many advertisements for heavy truck junk yards.
Call me if you have questions
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #7 of 13 (permalink) Old 06-16-2010, 04:08 PM
Pictures please !
Me2000 is offline
post #8 of 13 (permalink) Old 06-17-2010, 05:21 AM
I will when I get the time, It is a pain in the *** to down load pics on forums because I have to re size them all. Where do you live?
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #9 of 13 (permalink) Old 06-18-2010, 12:42 AM
Super Moderator
nevrenufhp's Avatar
No need to re-size, just dump em all on Photobucket or a similar picture hosting site. Then, you can dump the link in the thread, and all the work is done for you.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #10 of 13 (permalink) Old 06-18-2010, 01:32 AM
Picasa web works great too, if you have a gmail account.
Me2000 is offline
2005 cummins transmission Cummins_1984 Supporting Vendors Forum 1 01-09-2010 06:57 PM
12V Cummins to ZF5 speed transmission TLadd Diesel Conversion 3 05-15-2009 01:55 AM
Cummins Transmission issues powerstroke2003 5.9L Cummins (2003-2007.5) 3 10-30-2007 03:27 AM
Spicer 7 speed terl00 Medium and Heavy Duty 16 10-03-2007 02:47 PM
Transmission question on a 2000 cummins 00'CUMMINS 5.9L Cummins (1998.5-2002) 8 03-10-2007 03:24 AM
