7.3L into a 03' that had a 6.0 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PennyPinchingPowerStroke, this thread has received 1 replies and been viewed 1073 times.
post #1 of 2 (permalink) Old 03-02-2010, 05:44 PM Thread Starter
Exclamation 7.3L into a 03' that had a 6.0
Anybody know what it takes to do this? I have a 7.3 from a wrecked truck and found an 03 with a bad 6.0. Since this was the end year for the 7.3 and the begging year of the 6.0, will this work with realitive ease? Any shops that do things like this? Any input would be great!
PennyPinchingPowerStroke is offline
post #2 of 2 (permalink) Old 03-07-2010, 02:04 AM
That guy
thefermanator's Avatar
I'm sure it's doable if you have the right donor. You would have to swap the engine and trans as well as the harness though probably as they all changed when the 7.3L to 6.0L swap happened.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
