wet sleeve - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ironbrew, this thread has received 0 replies and been viewed 1740 times.
post #1 of 1 (permalink) Old 05-03-2010, 06:13 PM Thread Starter
wet sleeve
Howdy folks...
New to the list (post number one). I'm interested in doing a project vehicle, and I'm looking for a suitable engine. Haven't yet picked out the vehicle, as it will be dependent on what I find for an engine...
Interested in the 4BT series, BUT... if I can find a good wet sleeve 4cyl, I'd probably look that way. Blew up a 6BT (similar to KDP, but caused by a timing bolt of some sort... I sold the truck due to time) which makes me more interested in the wet sleeves. Dry sleeves are a second best...
The wet sleeve engines I've found have been the IH DT series (6 cyl requiring firewall mods in most vehicles, I believe - if you can even fit them). Dry sleeves are the Hino's. Does anybody know of a decent (read not humongous) 4cyl. wet sleeve suitable for a pickup? Should I be looking at the Hino's instead or stick with the DT series?
I'd like a 4 cyl as it gives me more vehicle choices...
Thanks
Ironbrew is offline
Ford AIS fender sleeve King0581 Supporting Vendors Forum 0 06-14-2009 11:52 PM
LB7 Fuel Injector Nozzle Tube Sleeve Replacement ripmf666 GM Spec Info 0 12-28-2008 10:30 AM
injector sleeve whitediesel23 2003-2007 6.0L Power Stroke 6 04-30-2008 03:41 AM
94 IDI turbo 7.3L sleeve or bore it? jap901 7.3L and 6.9 IDI (Pre 1994) 6 03-05-2008 03:02 AM
injector sleeve mudguy 1994-2003 7.3L Power Stroke 10 12-15-2007 12:34 PM
