12 valve in a '98 1500 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by southern-stroke, this thread has received 3 replies and been viewed 1221 times.
post #1 of 4 (permalink) Old 06-11-2010, 02:32 AM Thread Starter
southern-stroke
southern-stroke's Avatar
Send a message via MSN to southern-stroke
I'm considering doing an engine swap on my '98 1500 I drive daily. The factpry 5.2 has 178,000 miles on it and is starting to have problems. If i do the swap I want to do some work on the 12 valve before I drop it in. I wanna port and polish the heads, install studs, adjust the fuel, maybe injectors and maybe turbo. I'm gonna get a Goerend tranny for it. As for suspension, how much more will the front end sag with the 12 valve than with the 318? And finally, what's an estimated price on how much the switch would cost? Any input is apreciated.
''Can You Keep Up?'' while I'm ''In The Passing Lane!''
southern-stroke is offline
post #2 of 4 (permalink) Old 06-11-2010, 11:08 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
A guy on PavementSucks.com did it and it was pretty cheap IIRC. His name is Jeff and he used a '98 1500 QC with a '96 donor truck and transferred everything over. He made it a dually, rockwell axles, etc.. Not that you would want to do that because its your DD, but you could go on that site and search for posts by "SuperHawk2002" and you should be able to find his build.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #3 of 4 (permalink) Old 06-11-2010, 11:11 PM
Born in the USA
Here is a link to his q&a thread:http://www.pavementsucks.com/board/t...stions-answers
Tom
post #4 of 4 (permalink) Old 07-06-2010, 03:18 PM
1CAMWNDR's Avatar
Garmon Diesel Performance I think it is called in Ga. did a nice 1500/12V swap that was in Diesel Power magazine. 700hp and 35mpg. I think. That should be a great truck.
1CAMWNDR is offline
285/75/16 on a 1500 6.5??? b_doornenbal 6.5L Diesel Engine 6 11-14-2009 03:54 AM
Cummins in a 1500 badblackhemi Dodge Performance Forum 9 11-14-2007 08:37 PM
12 valve in a 1500 Sabbath5.9 5.9L Cummins 12 Valve (1994-1998.5) 6 09-19-2007 08:55 PM
500 ft lb at 1500 rpm?? Sader123 2003-2007 6.0L Power Stroke 8 01-02-2006 12:43 AM
99 1500 Deezle1 General GM Truck Forum 6 12-24-2005 03:54 PM
